Sundowner Valuelite
Last activity 2011-05-08 11:40 AM
1 replies, 3739 views
TBchick
Reg. Feb 2010
Posted 2011-05-08 11:03 AM (#133925)
Subject: Sundowner Valuelite
I found a 1998 Sundownwer Valuelite slant load that I plan on going to check out. I just want to clarify that the rust problem was with models 1999 and newer, correct? All the pictures look good on this trailer, but it's a long drive, so I don't want to waste $$ or time if there is an issue with this model year as well.
Seller has indicated that the trailer will need a new brake battery and new tires. Any idea ballpark of what those items would cost? I'm in the overpriced northeast if that helps with an estimate.
Posted 2011-05-08 11:40 AM (#133926 - in reply to #133925)
Subject: RE: Sundowner Valuelite
Emergency brake batteries are ~$20-$30. Tires are ~$150 -$250 depending on size and range for LTs
http://www.etrailer.com/dept-pg-Trailer_Breakaway_Kit.aspx
