hydraulic jack - apparently it needed a break
Last activity 2011-04-13 12:47 AM
4 replies, 5308 views
headhunter
Reg. Oct 2004
Posted 2011-04-12 2:55 PM (#132943)
Subject: hydraulic jack - apparently it needed a break
50010010025
While unhitching my trailer this weekend at a show, I had to raise and lower my hydraulic jack a couple of times when I realized I needed a bigger block of wood under the foot. After a complete up/down cycle, then up again, my jack just stopped working. I was not yet unhooked from the truck and not yet plugged into shore power. My batteries were new last year and stored inside out of the cold this winter. Did I suck down my battery juice and they needed to charge up a bit before continuing? I gave it a few minutes and tried again and it worked just fine.
Edited by headhunter 2011-04-12 2:58 PM
Posted 2011-04-12 3:04 PM (#132944 - in reply to #132943)
Subject: RE: hydraulic jack - apparently it needed a break
Hydraulic pump motor may have gotten warm shutting itself off to keep from overheating, or it may have tripped a relay/circuit breaker. Will your batteries recharge while being plugged up to your truck?
gonzo1066
Reg. Oct 2010
Posted 2011-04-12 8:08 PM (#132952 - in reply to #132943)
As your battery voltage goes down, the Amps to run the motor goes UP a lot,  the more Amps you draw the more heat is generated.  There is a thermostat device that shuts off the power when the motor gets hot.  If you have to run your jack several times just start your truck to provide additional power to the electrical system.      Charge your batteries and everything should be fine.
headhunter
Reg. Oct 2004
Posted 2011-04-12 10:47 PM (#132957 - in reply to #132943)
50010010025
The truck was running at the time and the trailer was still plugged into the truck so I suspect the truck is not recharging the trailer batteries although I don't know for sure.
Posted 2011-04-13 12:47 AM (#132958 - in reply to #132943)
Retento is likely right. Many high current/torque motors have a thermal switch built into their windings. The purpose is to prevent motor burn-out. The motor is designed to run for only a short time. Engine starter motors are prime examples of the type.
If the problem was weak batteries, the motor might have run but the hydraulic valve would not have opened ( see past threads on hydro jack issues)
