First lq trailer questions
Last activity 2011-03-31 6:38 PM
6 replies, 6167 views
WVbarrelracer06
Reg. Jul 2006
Posted 2011-03-30 1:43 PM (#132374)
Subject: First lq trailer questions
Are you suppose to leave them plug into electric to keep everything charge or just a day or so beforein useing and to keep the refig cold any helpful tips would be great thanks so much
dallyup
Reg. Mar 2011
Posted 2011-03-30 3:27 PM (#132378 - in reply to #132374)
Subject: RE: First lq trailer questions
I have a custom Featherlite. I have 2 deep cell batteries, and my refridgerator is propaine or electric. So to answer your question, it does not need to be kept plugged in all the time, but to keep the refridge cold and to save on propaine it does.
I keep mine plugged in all season, when in the yard, that way it is ready to go. The only time it is not plugged in at home, is if I am not going to use it for an extended period of time.
Happy Trails.. and good luck..
hornet
Posted 2011-03-30 7:19 PM (#132386 - in reply to #132374)
You have to be careful leaving them plugged in all the time. If you do, you must keep a close eye on the batteries. The typical factory charger is "dumb" and will over charge the battery and burn it up. I did this one year. In winters past I pulled the battery out since I didn't have power to where the trailer was parked. The first winter of having power at the trailer I left it plugged in, by spring the battery was burnt dry. Now I plug the trailer in for a few days, then unplug it for a couple weeks.
dallyup
Reg. Mar 2011
Posted 2011-03-30 8:18 PM (#132389 - in reply to #132374)
I agree totally.. If you are going to leave it parked for any length of time, you can't have it plugged in.
But during the summer, I just keep a close eye on my batteries..
Posted 2011-03-30 9:28 PM (#132394 - in reply to #132374)
If your Lq has a master switch, turning it OFF will prevent the batteries from over charging when continuously powering your trailer. If you don't, you can easily install a battery master switch like this:
http://www.amazon.com/BATTERY-CUTOFF-SWITCH-BOAT-RACECAR/dp/B001HSBW74/ref=pd_sim_auto_1
Edited by gard 2011-03-30 9:30 PM
WVbarrelracer06
Reg. Jul 2006
Posted 2011-03-31 4:29 PM (#132445 - in reply to #132374)
Okay not to sound dumb but what is the lq master switch. Also will the trailer charge the batterys when you are hauling like my other one did
hornet
Posted 2011-03-31 6:38 PM (#132457 - in reply to #132374)
Some trailers have a battery "master" switch some don't. My previous trailer didn't so I added one. It is just a fairly large, high current rating switch that disconnects the battery from the trailer. The switch is usually located close to the battery. As for your truck charging the trailer, if the manufacture wired it correctly it will. A simple check of the trailer plug for 12v on the charge pin while disconnected from the truck will tell you.
