Chevy 4500 question.
Last activity 2011-03-25 8:54 AM
6 replies, 4813 views
horsejunkie
Posted 2011-03-24 8:16 PM (#132089)
Subject: Chevy 4500 question.
We have a 2004 with air ride seats. We have put in three relays for the compressor. Now the compressor runs while the key is turned off and runs the battery down.. What's wrong? We've had several mechanics look at it. They replace the relay and it will work for awhile then back to the same problem. One mechanic said I had to empty the compressor to get the water out of it. But none of my friends who have these trucks do this.... Any and all advice would be helpful...
Thanks
Posted 2011-03-24 10:19 PM (#132092 - in reply to #132089)
Subject: RE: Chevy 4500 question.
Your mechanics aren't looking for the problem.  Air ride seats are not different than any other compressed air system.  Compressor pumps air into the system till something tells it to shut off.  The air pressure is either held or it leaks down, at which the compressor starts up again.
You have either or combination of: a leak, bad pressure switch and a miswired relay.
hogtownboss
Posted 2011-03-24 11:37 PM (#132095 - in reply to #132089)
10001001001002525
WOW, I did not know they had an electric pump.  My 6500 has a engine mounted pump that only works when the truck is running......
If your is running that much you should be able to hear the air leaking.  I would start at the seats, then go to the tank and follow the air lines also check the rear air bags if you have airride on the rear.
Next step if you can not find the leak is to intall a switch to turn the pump on when the truck is running...
Posted 2011-03-25 12:07 AM (#132097 - in reply to #132089)
Originally written by horsejunkie on 2011-03-24 9:16 PM
Thanks
tell the dealer to stop just changing the relay or compressor and check the duty time switch. The compressor runs a lot which causes it and/or the relay to fail.
horsejunkie
Posted 2011-03-25 7:09 AM (#132100 - in reply to #132089)
Our son took it to pickup bulls and stayed over nite and it ran the battery down while he was stopped overnite.. Sometimes when you are driving the engine airbrake alarm goes off and the only way you can stop the alarm is to pull off stop and turn the truck off..  I really appreciate the imput.. You all rock!!
Posted 2011-03-25 8:44 AM (#132104 - in reply to #132100)
Originally written by horsejunkie on 2011-03-25 8:09 AM
So, you got a 4500 with air brakes..??
Spin Doctor
Reg. Nov 2008
Posted 2011-03-25 8:54 AM (#132105 - in reply to #132089)
On our 4500, once in a great while the water drain on the tank will stick open after you drain the tank. It is wired to be only on when the key is on. We have air seats and air suspension and our compressor runs a couple times an hour when driving. Never when the key is off. Check out dieselplace.com, scroll down half the page and go to the medium duty section. They discuss the 4500 compressors a lot. Good luck.
Edited by Spin Doctor 2011-03-25 8:56 AM
