Black trailer exteriors
Last activity 2011-03-29 4:59 PM
18 replies, 19880 views
harnessup
Reg. Aug 2010
Posted 2011-03-23 11:43 AM (#132014)
Subject: Black trailer exteriors
So, are black trailers any hotter inside, esp if shiney black aluminum exterior and lined walls and ceiling? Thanks.
24cindy24
Reg. Feb 2010
Posted 2011-03-23 2:37 PM (#132020 - in reply to #132014)
Subject: RE: Black trailer exteriors
I have a Barrett with Black Skin and it is no hotter on the inside as an all aluminum one or one with white skin.
DD_TrailerMan
Reg. Jul 2008
Posted 2011-03-23 3:03 PM (#132021 - in reply to #132014)
YES, quite a bit hotter
Posted 2011-03-23 3:20 PM (#132022 - in reply to #132014)
Black will be the hottest of any colour
whitewood
Reg. Jun 2009
Posted 2011-03-23 3:53 PM (#132023 - in reply to #132014)
had an 04 sundowner 6 horse that we pulled for 2 years and couldn't tell any difference, except it showed the dirt worse.
blackcows
Posted 2011-03-23 6:01 PM (#132025 - in reply to #132023)
100100100100252525
Originally written by whitewood on 2011-03-23 3:53 PM
A friend has a black trailer and I agree with whitewood, never really noticed a difference in temp but always notice a difference in cleanliness...the black trailer always looks dirty.
akinstrailers
Reg. Apr 2009
Posted 2011-03-23 6:22 PM (#132028 - in reply to #132014)
I agree with Whitewood as well. I bought a black trailer just to see and there is not a noticeable heat difference in either the interior of the horse compartment or the exterior skin. Definitely harder to keep clean.
DD_TrailerMan
Reg. Jul 2008
Posted 2011-03-24 8:20 AM (#132042 - in reply to #132014)
ask yourself: do you think black cars are hotter than white cars?  There is your answer.
Mill finish shiny metal reaches a temp of 190 degrees in the summer sun, black is similar to that.
Posted 2011-03-24 8:48 AM (#132045 - in reply to #132014)
Look at any boat yard or marina. How many black boats do you see as compared to the white?
pinkmouse
Reg. Jan 2009
Posted 2011-03-24 9:27 AM (#132047 - in reply to #132014)
"I bought a black trailer just to see..........."
Wow - that's an expensive way to find out!!!! I wish I had that kind of money!
IMHO it would be easiest to go to a dealer on a sunny day, find 2 similar trailers - one white/one black - and stick a thermometer in them.
akinstrailers
Reg. Apr 2009
Posted 2011-03-24 11:47 AM (#132060 - in reply to #132014)
Pinkmouse:  We are a dealer which is why we had to bite the bullet and see. Obviously heat wasn't our only reason for purchasing a black trailer, we also wanted to see what the market was for them.
I don't know anything about boats, all I know is from firsthand observation on an 80+ degree day that I couldn't tell the difference.  Maybe I should have used a thermoter :
akinstrailers
Reg. Apr 2009
Posted 2011-03-24 11:52 AM (#132061 - in reply to #132014)
I forgot to add that it did surprise me because intuitively I thought it'd be much hotter.  Maybe you'd be able to tell a big difference if it was closer to 100.
whitewood
Reg. Jun 2009
Posted 2011-03-24 3:03 PM (#132071 - in reply to #132014)
had a 6' short wall that was lined and insulated from the factory and an a/c on top. Only overnighted in it a half a dozen times, but the a/c would freeze you out on a 100 degree day. We used it hard, probably put 70,000 miles on it and don't believe it was 1 degree warmer than the white skins we have or had. Had horses tied to it a lot, and the black also showed the horse damage much worse than white. Bottem half was extruted so that saved some.
Posted 2011-03-24 6:16 PM (#132081 - in reply to #132014)
http://msgboard.snopes.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2...
ornerie
Reg. Sep 2010
Posted 2011-03-25 2:37 PM (#132130 - in reply to #132014)
Location: Seattle "pshaw, its not raining hardly at all!" WA
while the interior of the black trailer may or may not be appreciably hotter than the interior of a white trailer (especially if insulated), the surface temp of a black surface will be way hotter than the surface temp of a black surface.
if you plan on TOUCHING the outside of your trailer (or if your horse bumps it with his tender nose), you may want to consider that as a factor.
of course if you live up here in the PacNW, having a passive solar heating surface may not be a bad thing ;)
whitewood
Reg. Jun 2009
Posted 2011-03-25 3:50 PM (#132133 - in reply to #132014)
not buying that theory, just checked it out on my wifes white car and my black pickup. The only ones I saw that got hot!!!!!!!!!!!!!! stainless steel.
Posted 2011-03-25 10:34 PM (#132148 - in reply to #132014)
http://www.tom-morrow-land.com/tests/cartemp/index.htm
harnessup
Reg. Aug 2010
Posted 2011-03-28 1:34 PM (#132267 - in reply to #132014)
Thanks for the input. My own thought would be that as long as it is shiny and reflective, it wouldn't have a lot of impact, but I don't own one. Came across one in a search and one person thought it would be hot inside.
gonzo1066
Reg. Oct 2010
Posted 2011-03-29 4:59 PM (#132331 - in reply to #132014)
I dont know about horse trailers,  BUT I do some drag racing, and sitting in a black car is MUCH hotter  MUCH HOTTER than sitting in a white or other less dark car.   Your trailer insulation should help with this quite a bit.    If I was hauling in a black trailer the roof would be white.
Edited by gonzo1066 2011-03-29 5:01 PM
