no hot water in our trailer
Last activity 2011-03-23 7:48 AM
1 replies, 3441 views
vickie63
Reg. Mar 2011
Posted 2011-03-22 10:44 PM (#131998)
Subject: no hot water in our trailer
I have a 1988 Komfort trailer and there is no hot water. Everything is lite but it will not get hot. Anyone know what I need to look at or fix to make it work again.
whinneyman
Reg. Oct 2007
Posted 2011-03-23 7:48 AM (#132007 - in reply to #131998)
Subject: RE: no hot water in our trailer
Check the water bypass used for winterizing the water heater, if it was winterized then the drain plug needs to be reinstalled. Running without water in the tank should cause the high temp limit to kick out and it will need to be reset.
Whinneyman
