Any TieRite users?
Last activity 2014-05-22 11:33 AM
18 replies, 14456 views
bjhouten
Posted 2011-03-01 4:40 PM (#130948)
Subject: Any TieRite users?
5002525
Anyone using a TieRite tie their horse to your trailer? They are a $100 off on Long Riders Gear and I'm thinking about getting one. Has anyone over nighted in their trailer with a horse tied to the TieRite? How's the trailer movement?Thanks,Betty
Rockin_horse72
Posted 2011-03-01 10:00 PM (#130967 - in reply to #130948)
Subject: RE: Any TieRite users?
I dont have the "Tie Right" brand, but I have the same thing on my trailer. I have used it for my mare and it was great! Mine had a spring on it and I could hear it at night, but it wasn't anything that bothered me. I believe that the one you are looking at doesn't have the spring on it. It is really nice to be able to pull into any camp ground and have my horse very comfortable with "her" normal set-up.
Posted 2011-03-01 10:31 PM (#130973 - in reply to #130948)
I've had several trailers with the HiTie system and strongly reccommend them.  I've had to camp alot of nights where there were no trees or corrals.
I sleep much better with these than just tying to the tie rings on the side of the trailer
Posted 2011-03-02 1:20 AM (#130978 - in reply to #130948)
I see Paul Bunyan has been through that neck of the woods...
Bells
Reg. Jun 2007
Posted 2011-03-02 9:48 AM (#130996 - in reply to #130948)
My neighbor has one - she finds it a little hard to lift into place. She is about 5'3" though.
Posted 2011-03-02 10:20 AM (#131001 - in reply to #130948)
Paul,  That's an interesting way to look at it.
In the summer months when we go to high country. We have no problem finding trees to high line off. But during the cold weather when we ride in the desert. There are no trees.  So you either, put up an hot wire, tie to the trailer or use something like the HiTie.    I don't trust hot wires at night when I'm asleep. Horses push each other through the hot wire or deer/elk run thru and knock the wire down.  If I tie directly to the rings on the trailer, I feel every tug and get a horrible nights sleep.
As far as height. I really like to get them up as high as possible.  But 7' tall trailers especially if they have anykind of a radius on the roof,  Often max out how high you can mount the hities at 6' or 6'6". With a tall horse, that's just not high enough.  I'm 6'2" and with my long arms I can reach 8' high. And that is where I prefer to mount my HiTies.  A shorter person will have to get some help ( in a stool or step ladder) to extend and lock in place Hities that mounted that high up. But I think that is worth the effort.
Regardless at what height, The units are mounted, I'm going to tie my lead rope at such a length that the horse can barely stretch/flex the unit to touch his nose to the ground direct;y beneath the tie point. The higher the unit is mounted, the longer the lead can be and still not allow the horse to touch the ground.  The longer lead hanging from the tie allows a greater circle for the horse to move about with in. Essentially giving the horse a larger circle to walk/move about in.  I also often ride attach/remove the lead rope while I'm in the saddle, So I prefer the rod to be high enough that it won't scrape me off the saddle if a horse turns or dancing while next to the trailer.  It's all personal preferance. But I like mine as high as possible.
The HiTies come with a bungie connector for the connections between the Fiberglass Rod and the halter.  I never use them.  I just attach my lead ropes driectly to the fiberglass rod.
CTRider
Reg. Sep 2009
Posted 2011-03-02 1:15 PM (#131009 - in reply to #130948)
10010010025
We had the Tie Rite's on a previous trailer. While I really liked the design and ease of use since I am short, they tend to bend if you have a horse that pulls alot. I have Spring Ties on my current trailer and like them alot. The horse can pop the spring and make a noise but I kinda like hearing it to be sure he is still out there. Also it could mean he has managed to get in a bind and would alert you to check on him. With that said, we do Competitive Trail with NATRC where we are required to tie our horses stationary all night. Since 2003 when I started I have only seen 3 horses get hung up or in a bind on Hi Ties or Picket lines.
And Painted Horse is correct, the higher the better.
Cowgirl999
Reg. Mar 2008
Posted 2013-06-17 6:22 PM (#152827 - in reply to #130948)
I just took one off my trailer and have it for sale for $225.00. Am located near Roanoke, VA
bjhouten
Posted 2013-06-18 3:10 PM (#152838 - in reply to #130948)
5002525
I really want to add a couple of these to my trailer. I was at a clinic and a lady had put a yacht clamp on her TieRite. It has a rope that hung down so all she had to do was pull on the rope to release the horse from the TieRite in an emergency.
trot-on
Reg. Dec 2009
Posted 2013-06-20 11:26 PM (#152863 - in reply to #152838)
Originally written by bjhouten on 2013-06-18 3:10 PM
I make those., ;-) http://trotonhank.blogspot.com/2013/04/hi-tie-ropes-for-over-head-t...
Edited by trot-on 2013-06-20 11:27 PM
Posted 2013-06-21 2:12 AM (#152864 - in reply to #152863)
Originally written by trot-on on 2013-06-20 11:26 PM
I make those., ;-) http://trotonhank.blogspot.com/2013/04/hi-tie-ropes-for-over-head-t... are very nice...:)
desert ice
Reg. Jul 2012
Posted 2013-06-22 6:47 PM (#152891 - in reply to #130948)
Put a TieRite on my trailer 6 months ago and just love it. So much easier than portable corrals, and I don't hear or feel anything at night. Easy to raise up (I'm a 5'4"woman) and I did the installation myself. Considering adding another on the other side as we camp with 2 horses.
dweber2000
Reg. Oct 2008
Posted 2013-08-31 9:05 PM (#154443 - in reply to #152827)
Sold it? If not very interested. Need brand name and pics. Deb weber Dweber2000@aol.com843-333-3418
dweber2000
Reg. Oct 2008
Posted 2013-08-31 9:08 PM (#154444 - in reply to #152827)
Originally written by Cowgirl999 on 2013-06-17 7:22 PM
See reply. Dweber2000@aol.com. Looking to buy Hi-Tie.
LNM
Reg. May 2014
Posted 2014-05-21 8:55 PM (#159166 - in reply to #130948)
I purchased and install April 2010. Like the heavy duty straps that attach to horse trailer. works well with my trail horse, am retired so from May to October go horse camping often.
The flexible arm broke straight across close to the metal portion closes to trailer. I do use a swivel at the end to attach horse. it is black and 1 1/4 inch diameter. quoting me $75 plus $20 shipping just for the flexible arm portion. hmm.
Enumclaw, WA
walkin
Posted 2014-05-22 6:38 AM (#159169 - in reply to #130948)
500100
Which brand broke?
LNM
Reg. May 2014
Posted 2014-05-22 10:24 AM (#159174 - in reply to #159169)
Tie Rite TM 001. the flexible arm portion is black. 1 1/4 inch diameter.
LNM
Reg. May 2014
Posted 2014-05-22 10:39 AM (#159175 - in reply to #130948)
Good luck if the arm does break. they do NOT sell the arm with the metal attachments. they will sell only the flexible portion of arm for $95 with shipping. really? that one part costs that much. and also good luck getting the metal fitting off the flexible portion. the flexible portion broke even with the metal part, looks like a knife sliced it. my horse was NOT jerking on it nor panicking and putting all her weight on it.
LNM
Reg. May 2014
Posted 2014-05-22 11:33 AM (#159176 - in reply to #130948)
mine was purchased April 2010. failed May 2014 at the flexible arm connection with metal fitting. no replacement part with the metal fittings from manufacturer.
