Trailer Door Hinges
Last activity 2013-03-01 10:11 PM
16 replies, 26235 views
Posted 2011-02-23 12:03 AM (#130619)
Subject: Trailer Door Hinges
Recently I stated that Sundowner used two hinges on each of its rear doors, whilst most other manufacturers used three or even four. In a rebutal, a representative of Sundowner made the following statements:
"The reason Sundowner only has two hinges per door is because strap hinges are a weaker design than the one Sundowner uses. So you need 4 or 5 strap hinges to do the same job of just two Sundowner hinges. Actually two of the Sundowner hinges work better than the 4 or 5 strap hinges with the force of a kicking horse"
"When a horse kicked a trailer with rear doors with strap hinges it knocked the door out of align "
Based on my ownership of two different trailers equipped with strap hinges, I became curious to see if I were the only one not to experience any difficulties with bolt on hinges. I spent a few hours contacting various trailer owners I know, and came up with the following representations. Sidekick (1), Exiss (3), Sooner (2), 4Star (2) Kiefer (1) Logan (1) and Featherlite (3
They resulted in 13 trailers, 26 doors and 90 bolt on strap hinges. The trailer ages were 1996 to 2010. None of my acquaintances currently own SD equippment. Not one trailer owner, including me, ever had a hinge problem that resulted in a door either sagging or being out of alignment. The most common issue was proper hinge lubrication for the older trailers. The doors' operation became stiff when proper maintenance wasn't observed.
In addition, three of the owners I questioned, had trailers that featured welded hinges instead of the strap type. These trailer brands were Elite (1), Hart (1), and a Cimarron (1). These brands became most interesting, particularly in light of the SD representative's statement, with SD only using two hinges because of their superiority.
 The Elite had 4 welded hinges per door; the Hart had 4 welded hinges, and the Cimarron had 5 welded hinges per door. None of them had any hinge difficulties or sagging doors, but then you wouldn't expect them to with a least double the number of hinges.
All told, in the lot were sixteen trailers, twenty nine doors, one hundred sixteen hinges and no failures. I realize these number are too low to make an "official" survey. But based on their results, I find that strap hinges are just as reliable as welded. They also have the advantage of being easily replaced, if ever they are damaged.
My original statement alluding to more hinges being better than two, seems to be born out by the construction methods used by most of the major brands of trailers.
Just my $.02
d2allen
Reg. Jan 2011
Posted 2011-02-23 12:07 PM (#130643 - in reply to #130619)
Subject: RE: Trailer Door Hinges
Gart,I'm glad you started a new thread on trailer door hinges.Your survey proves that 4 or 5 strap hinges hold up just fine in a number of quality built trailers. What you haven't proven is that the Sundowner hinge design is somehow inferior (given that S.D. trailers only use 2 of them.) Have you examined Sundowner's hinges? How are they different than strap type hinges? Details like this matter.d2allen
sundownerofaiken
Reg. Jul 2009
Posted 2011-02-23 2:39 PM (#130653 - in reply to #130619)
The problem is not with sagging on the strap hinge.  The problem I had was when the door took a direct blow from a horse the door bulged out 3/4" from the door frame.  The Strap hinges bent out. Not down.
Rick
Sundowner of Aiken
Posted 2011-02-23 3:01 PM (#130655 - in reply to #130643)
Originally written by d2allen on 2011-02-23 1:07 PM
I haven't tried to prove anything. I was asked to point out differences among the trailers, which I did. Many aluminum SDs are out there and have been around for years. This proves their design works.
What I described was a two point door suspension, that offers little strength where the horse's butt will strike it. I personally watched a SD door being bent in the middle, when an errant horse backed into it, when a butt strap wasn't attached. The fact that SD stands pretty much alone in the industry with two door hinges, while everone else reinforces their doors with middle hinges, should be a clue. The Exiss brand has three hinges from the middle down, the area most impacted by a horse. In addition it has a fourth at the top.
When I started the thread about the details, I said that I wasn't interested in initiating a flame among the various trailer brands. You asked for differences and I gave a few. Details do matter, that was the point of my thread. It's up to you to become informed enough to make an intelligent decision. I have tried to offer constructive information, but I will not be held responsible for your final decision. I don't have to prove anything. You have to make up your own mind.
My background differs from yours. What I value in a construction, and how I use my equippment will vary from your ideals. I have chosen my purchases based on my beliefs. You have to do the same.
sundownerofaiken
Reg. Jul 2009
Posted 2011-02-23 3:30 PM (#130658 - in reply to #130655)
Guard,
On the Sundowner you observed was there a failure of either the door or hinges?
Posted 2011-02-23 3:41 PM (#130659 - in reply to #130658)
Originally written by sundownerofaiken on 2011-02-23 4:30 PM
Guard,
Absolutely. The door bent in the middle where it wasn't supported.
BTW. I'm not, nor have I ever been, a guard.
whitewood
Reg. Jun 2009
Posted 2011-02-23 4:02 PM (#130661 - in reply to #130619)
my background is different from yours also. Over 7 years I saw over 2000 Exiss and 2000 Sundowners and a few Sooners new and used come and go and don't sell any of those today. from the hobby/trail rider user that didn't matter what they owned, to ranchers on 30 miles of gravel and rock(if you want to call it that) to the rodeo people that made their living out of a trailer. Sundowner made some mistakes that come to mind like the black hinge on doors and drop downs, the Sun coat on the steel frame trailers, but the only back door hinge problem they had is once in a while one would sieze up and break. Never saw a frame issue with any of the brands common to this area. everybodys stock combos did great and there are a lot of featherlite, C&C, Platinum,elite, and 4 stars. All the exiss had a few drop down window problems either hinge or had wood in them that just got rotten. The sports had such light duty manger doors that just wanted to sag. Had lots of back door problems with sports including just falling off . Trailer got in the hands of an NFR header. The 720/725 sundowner were as tough as anything out there.
sundownerofaiken
Reg. Jul 2009
Posted 2011-02-23 4:48 PM (#130667 - in reply to #130619)
Gard,
Sorry about the spelling.  So the door did not bend back on it's own?
RTSmith
Posted 2011-02-24 9:27 AM (#130708 - in reply to #130619)
As Gard said, not trying to flame anything. But there are a couple of points I think are important not yet noted-
We are jumbling hinge design, and attachment together as one topic- that might really should be seperated into two
Hinge design will be dependant on door design. Those manufacturers that wish to have wrap-around doors will use a hinge that is long enough to allow the door to wrap. Thus the "strap hinge". Now in that variety of strap hinges, we seem to see stamped and cast. As Aiken said, we repair guys have seen the stamped ones be bent out of shape regularly. We just bend them back & go on. And yes- I have seen a door with 4ea stamped strap hinges have at least 3 bent when a horse backed into it (outside of the trailer none the less, door just hanging semi-open). But we were able to reshape them with little effort (probably about the same amount it took to bend them..:) )
The cast strap hinges are stronger, but will snap rather than bend if pushed hard enough.
Sundowner and several others doen't use strap hinges, because their doors (on regular horse trailers, stocks are different) don't wrap around. I suppose these would be described as "regular" hinges. Because of their shorter size, these are likely going to be stronger and less prone to damage, but are limited to 180 degrees of door swing.
Welding or bolting- Your choice?
Sundowner hinges have been welded or bolted on through the years. Either method seemed interchangable, but recently bolting seems to be their preference. Elite trailers have welded hinges. Both are of the regular design.
I believe every strap hinge I've seen was bolted on.
Third point- bearing surface. Some hinges have more bearing surfact than others. This surface is what carries the load. The engineer will need to determine how much he needs for his/her application. And as Whitewood pointed out- lubrication to keep it from seizing. Jamco & Sundowner are using zerk fittings. Elite incorporates a special bushing that self-lubricates with no attention required. Some manufacturers have neither, and require one to use lithium lube, etc.
Just a few points to ponder. Sometimes there's more than meets the eye, and no "best" answer. And with over 100 mfg. out there, I have not tried to list everyone, just some that came to mind.
RTSmith
sundownerofaiken
Reg. Jul 2009
Posted 2011-02-24 1:31 PM (#130726 - in reply to #130619)
RTSmith,
Very well said thank you for the clarification. I think that will help folks understand the differences a little better.
d2allen
Reg. Jan 2011
Posted 2011-02-24 2:28 PM (#130730 - in reply to #130655)
Gard,Please accept my apologies for anything I wrote that offended you. Your survey resulted in data which I used to draw 2 conclusions: (1) trailers that have 4 or 5 hinges hold up just fine to horses kicking and backing into the door; (2) some trailers have only 2 hinges per door, but you offered no data (survey numbers or incidents) to say if they hold up or not. Perhaps the word "prove" was too strong? Perhaps I should have used the word "demonstrated". Except in your follow-up you mention witnessing a trailer door being bent in the middle, so now I understand why you might think 2 hinges are insufficient. One example like that is not exactly "proof", but it's certainly useful information.Yes, I asked for construction differences, all in the interest of understanding how horse trailers are built and how that relates to safety, durability and resale. None of my questions or comments are for the purpose of "flaming" one brand or another. I don't know where you got the idea that I would hold you responsible for my decision. I fully intend to make up my own mind and not hold you or anyone I meet on any internet forum responsible for my decisions whatsoever. My background is in science and law, so I tend to gather as many facts as I can before making a decision. This isn't easy because the information regarding horse trailer construction is hard to locate and much of it anecdotal. In a perfect world one would tour the factories where these trailers are made. Driving distance to Sundowner, Exiss and Featherlite dealers is 100 to 150 miles one way (all in different places). I've been to all 3 once, would love to go back and examine hinges and other details, but it's not practical. Which is why this forum and discussions about trailer design and construction details is so useful to me. Please know I am truly grateful for this forum and the information you provide. d2allen
Posted 2011-02-24 4:25 PM (#130735 - in reply to #130667)
Originally written by sundownerofaiken on 2011-02-23 5:48 PM
Two years ago I and my family were at a show in OH. As my wife and I walked beside my daughter while exiting the show ring, we passed a mother and teen age daughter trying to load the second of two horses into a 3HSL SD trailer. The horse would partially enter, rear and then forcefully back out. This happened several times while we watched. The other previously loaded horse started getting edgy, and proceeded to stomp and shuffle about.
Another couple who apparently were traveling companions came to help. They brought two whips. Again the horse was led partially inside, reared and refused. This went on for several minutes as the owners lost their cool, and decided they would MAKE the horse load. When the horse again had its front end in the trailer, the other couple used their whips to force the horse forward into the stall. As soon as the rump cleared, the daughter closed and latched the right rear door.
In seconds there was an explosion of noise and movement. The horse was slamming and kicking the insides of the trailer, and especially the rear door. The cadence and ferosity increased dramatically and everyone was yelling, but not knowing what to do.
The noise suddenly stopped and the mother ran to the head side drop window. After looking inside, she screamed "he's down". There was then a discussion about what should be done. One of the companions went to the rear door to open it. Before he could, there was a loud bang and the trailer looked like it jumped off the ground. The door flexed on its hinge side. A second bang and more movement then occured. This time the whole door flexed and bent in the middle.
The motion and noise soon stopped, and once again they decided to open the door. The vertical bar attached to the latch handle was bent. The lower cam lock was jammed into the bottom casting. They could not release the door and open it. A grounds keeper had a utility vehicle, and drove it to his maintenance area to get some tools. He returned with a hand sledge and a crow bar. The lower fitting was struck until it was destroyed. This permitted the rod and the top camlock to rotate, allowing the door to open.
The horse was badly shaken, on his feet and bleeding from several areas of his legs, hip and face. He was unloaded and taken away to be inspected and cared for.
When we approached the trailer to check on the other horse, the right rear door was open, and noticeably sprung in the middle. Upon closer inspection, the bottom hinge boss was cracked from the outside surface to the hinge pin. The vertical locking bar was bent, and the lower cam lock and its receptacle were mostly destroyed by the hammering.
The horse survived, and was again being ridden, when we spoke to the owners at one of last year's shows. They were then owners of a 4Star trailer.
sundownerofaiken
Reg. Jul 2009
Posted 2011-02-24 4:37 PM (#130736 - in reply to #130619)
Gard,
Thanks for the info. Of the 500 Sundowners that have run through this shop in the last few years this is a first for me. I will present this info to Corp and see if any other cases have accurred.
Rick
Sundowner of Aiken
RanchRider*5
Reg. Feb 2008
Posted 2011-03-12 12:09 AM (#131553 - in reply to #130619)
I have a 5 horse slant SD trailer that works great, but the back hinges have wore down on each other to where the back loading door sagged about 1/2 inch or more.  We had to take the hinge pin out and place a couple of washers between the joints to bring the door back up to where it should be.  Looks like the alum. just couldn't hold up under the weight of the door. (Or it could be the 20 miles of gravel we have to travel each time we leave home??)
Bill Grant
Reg. Mar 2013
Posted 2013-03-01 5:26 PM (#150285 - in reply to #130619)
Hi everyone,
I am a novice in this field and I need help finding a good supplier for my hinges. I'm interested in buying hinges from here http://www.spep.com/ but they don't sell to individuals, it's a $150 minimum order. I need these models: http://www.spep.com/Blog/Take-ApartHinge.html and http://www.spep.com/Blog/Stainless-Steel-Strap-Hinges.html.
Could anyone recommend me a good source? Any help will be welcome!
Thanks,
Bill
slowrider
Reg. Apr 2010
Posted 2013-03-01 7:33 PM (#150288 - in reply to #130619)
I don't know whether this company has what you are looking for, but we are do-it-yourselfers, and have had great dealings with this company. shetronmfg@embarqmail.com We just email and tell them what we're looking for, and if they have it, you can get it. We find their prices reasonable, too.
Spin Doctor
Reg. Nov 2008
Posted 2013-03-01 10:11 PM (#150291 - in reply to #130619)
A few points that has yet to be mentioned, are that the bolt on hinges can be easier to adjustreplace than the weld on hinges. I have had door channels and door frames get tweeked at the hinge attachement point and bind the door. On bolt on hinges, it is easier to adjust to make the door swing freely. On weld on, you must fix the tweek or reposition by rewelding.
Also, the less number of hinges on the doors, the easier it is to manufacture. Extremely close tolerances are required in lining up 3 or more hinges to operate propperly.  Using just 2 hinges, tolerance is very forgiving and less skills/costs are needed to produce.
I have bent trailer doors with 5 hinges as well as those with 3 when exposed to enough force. I have noticed on the weld on hinges, the extruded frame is what bends/breaks, not the hinge. On bolt on, it is typically the hinge.
What is best? IMO the more hinges, the better. Call me closed minded, but I would not consider a trailer with 2 hinges on any door exposed to livestock.
Just my observations.
