feedback needed on 2006 F450
Last activity 2011-02-16 5:14 PM
10 replies, 7376 views
SarahR
Reg. Jan 2008
Posted 2011-02-14 4:51 PM (#130273)
Subject: feedback needed on 2006 F450
I posted a few weeks ago about getting a bigger truck. Our trailer fully loaded is about 17,000. We think an F450 with the towing package would be pretty good. We found a 2006, but it does have the 6.0 liter PSD engine. What we have read online is that by mid-05 Ford had resolved the issues with the 6.0. Is it a huge mistake to buy this model year, with that engine? Our current truck has the 7.3 liter engine, is it going to be a big disappointment when we go to haul up into the high country?
Posted 2011-02-14 6:44 PM (#130277 - in reply to #130273)
Subject: RE: feedback needed on 2006 F450
Sarah, The 6.0L as they age have had a few common problems.
FICM ( Fuel Injector Control Module)  This is usually some solder joints become weak and you have loss of voltage. I think a new module is $400 $500. But there are several threads on the Diesel websites that  give directions on how to pull the module and resolder the weak connections and how to test.  So if you do it yourself, It's an afternoon for hubby. If you take it into a dealer, it will be the $500 in parts and half a days labor. So $800-$1000
http://www.thedieselstop.com/forums/f50/detailed-ficm-repair-procedure-244155/
Mine went bad at 90,000 miles
HPOP  The endcap on the High pressure oil for the fuel injectors has a tendency to leak.  When it does, the dealer needs to pull the valve cover and rebuild that part.  I had mine done at the same time as my FCIM. The bill would have been $1800 for both. But since i was under 100,000 miles and 5 years. The warranty covered it.
EGR  The egr is a $400 repair if it becomes plugged
EGR Cooler.  This is cooler that cools exhaust that is being recirculated back into the engine.  The part itself isn't terrible expensive, But you have to remove a lot of components to get to it. So the labor cost get expensive.  I never replaced it on my trucks, But it seems to be a common topic in the repair forums for the 6.0. I think if you are going to drive that truck to 200,000 miles, It's probably something you will see along the way.  Here is a detail explaination of whats involved and an aftermarket replace part. http://www.bulletproofdiesel.com/Articles.asp?ID=146
If the truck has been chipped at. Head gaskets seem to be at risk.  The common repair is to replace the head studs with those that will withstand more pressure.
I use my trucks hard.  they have some sort of a trailer hooked up almost daily. They do lots of short trips and start and stops. All in all, I was happy with my trucks that had the 6.0L. The 6.0L is a little weak when trying to get rolling from a stop with a load. Thats why ford went to 6.4L and now the 6.7L  to give them a little more umph.  There were a few minor problems, In my case they were repaired under the 100,000 mile warranty.  I did pay for the following
2nd gear silenoid  About $700 at about 70,000 miles
Clock Spring in steering wheel $200   at about 80,000 miles
Speed sensor in rear end  few hundred dollars at about 40,000 miles
I went thru 4 glow plugs.  They are $29 a peice, But $200 to open valve cover to install. The dealer swears they rarely ever replace any glow plugs on other 2005-2007 6.0L.  In fact he claims they only keep 2 in inventory because they replace them so seldom.
Spooler
Reg. Aug 2006
Posted 2011-02-14 8:16 PM (#130285 - in reply to #130273)
50025
Don't get it. The 05' and 06' still have engine issues. Watched an 05' melt down right in front of me in the mountains.
hogtownboss
Posted 2011-02-14 9:38 PM (#130295 - in reply to #130273)
10001001001002525
Originally written by SarahR on 2011-02-14 4:51 PM
2003 to 2007 are pretty much the same engine.  The 03 and 04 being the best for least amount of egr problems 05 being worst of the bunch for turbo problems.  Just like ANY engine there is issues with all of them.
If the truck is priced right I would buy it in a heart beat.  The biggest issue with these engine while towing is the egr and egr coolers which about $300 to $600 bucks or so plus labor (if you do not do the work yourself) can fix for good.  The FICM can also cause rough idle issues but mainly on 03 to 5 models.
Best way to check for egr troubles before you buy the truck.  Remove the coolant cap and check for signs of oil or diesel by smelling of the cap and looking into te tank.  If is smells like anything but coolant either pass it up or call me and check it out further and offer them a big cut on the price and fix it.  I am working on a 05 4x4 F-250 right now that haa/ had egr troubles and I am fixing it the right way so there will never be an issue with that part again.
The only real issues with the F-450's was the ones with 4.88 gears starting making rear end noise around a 100-k and this is a $1000 fix.  The trucks with 4.30 gears was just fine.
GRNMCHNEDAZE
Posted 2011-02-15 8:08 AM (#130309 - in reply to #130273)
10010010025
I have an 06 6.0 and it has been a relatively trouble free truck. Right after I purchased mine, I took it to be checked out by a friend of mine (Ford diesel mechanic). They "fixed" (deleted) the EGR cooler, replaced 3 sticking injectors, replaced the oil cooler, and rebuilt the turbo. The truck was under warranty so the injectors, oil cooler, and turbo were covered. I have done several low cost things to ensure this trucks reliability.
Something else you may want to check besides the coolant is the oil. Make sure it doesn't look like chocolate milk. Thats a dead give away for headgasket issues. Also look for white flakely residue around the coolant cap. It would look like it spewed out. That can be a sign of EGR cooler/Oil cooler problems and usually headgaskets are next in line.
You can call any Ford dealer and have them run an "oasis report" on the vin #. This will tell you what warranty work has been done to the truck which will be a pretty good indicator of whether it is a problem engine or not.
 As for being a towing disappointment vs. the 7.3, I will get flamed for this, but my opinion is that the 6.0 pulls better than a 7.3. The 6.0 is an amazing engine and the later years (06-07) had less warranty claims than any years of the 7.3. (I'm not saying its a better engine-thats a longshot, I just don't think people give the 6.0 the credit it deserves.)
Edited by GRNMCHNEDAZE 2011-02-15 8:10 AM
hogtownboss
Posted 2011-02-15 1:42 PM (#130339 - in reply to #130309)
10001001001002525
I agree with you 100% on the bold statement!  Too many people jump on the bashing band wagon because they "heard about something or a friend of a friend had trouble"  Very few actual real time owners bashing.....
The first part of the quote I have to ride the rail....  I have used some bone stock 6.0's that would hardly pull our 10'LQ 3 horse Sundowner but had a couple that would pull the hitch right off of the trailer (in stock form)  But on the other hand after deleting the egr and egr cooler then adding exhaust/air intake and mild chip or programer I would put any of the 6.0's agaist any of the 7.3's on the road.
GRNMCHNEDAZE
Posted 2011-02-15 2:44 PM (#130345 - in reply to #130339)
10010010025
[\QUOTE] The first part of the quote I have to ride the rail....  I have used some bone stock 6.0's that would hardly pull our 10'LQ 3 horse Sundowner but had a couple that would pull the hitch right off of the trailer (in stock form)  But on the other hand after deleting the egr and egr cooler then adding exhaust/air intake and mild chip or programer I would put any of the 6.0's agaist any of the 7.3's on the road.
Fair enough. You have a much larger experience with them than I do. I should have put the disclaimer "based on my experience."  With mine having the EGR cooler and valve deleted and a SCT tuner (with a very mild custom towing program-mainly for the "turbo brake"), it will rock and roll. I'm itching to get my headstuds installed.
When we go camping, we caravan with about 5 big LQ trailers. 2 7.3's, 2 6.0's and a duramax normally. They are all great trucks with good engines. We don't pull fast so they all do everything we ask and nobody has had too much trouble.
Edited by GRNMCHNEDAZE 2011-02-15 2:46 PM
gonzo1066
Reg. Oct 2010
Posted 2011-02-15 10:05 PM (#130362 - in reply to #130273)
One of my best friends lost 4 6.0 engines in 2 trucks.   The first one was a 2003 and the second one was  a 2005.  His Ford dealer was not helpful in solving the problems. His trucks were NOT chipped, however they did pull a large GN trailer whenever they were started.   He now pulls the same 14,000# trailer with a medium duty Freightliner.   His troubles cost him dearly.   Having said this my sister owns 2 6.0's and loves them.
SarahR
Reg. Jan 2008
Posted 2011-02-16 3:08 PM (#130392 - in reply to #130273)
We decided to pass on the truck. We did a VIN search and this truck had already had lots of issues that we weren't comfortable with. We are refocusing on looking for a 99-03 7.3 F550. Thanks again for all the info!!!!!!!!!
horsey1
Reg. Dec 2004
Posted 2011-02-16 4:10 PM (#130393 - in reply to #130273)
Sarah- Just re-read that note HTB put out there about the 4.88. I lived with a '99 F-450 for a long while. You will like it in the mountains. But with the factory drivetrain, this is basically a 55 MPH truck. Any faster and you're twisting that 7.3 pretty high, she wears out quick, and flat gulps the fuel. At 55 not too bad. If that's what you need, go for it. But do go in with your eyes opened.
hogtownboss
Posted 2011-02-16 5:14 PM (#130394 - in reply to #130392)
10001001001002525
Originally written by SarahR on 2011-02-16 3:08 PM
YEAH, You and me both....  I love my Dodge with the 6.7, but if I could ever find a F-450 or even a F-550 with the 7.3L engine in a crew cab truck I would buy it in a heart beat.  Heck I have even been looking at the XL package work trucks to fix up but most of them are torn up pretty good on the inside and dents all around the outside.  Don't mind doing a little work but in and out I will have to pass.
Good luck on your search.
