Trailer Tire Wear
Last activity 2011-02-14 11:23 AM
3 replies, 3879 views
SunChick
Reg. Feb 2011
Posted 2011-02-14 7:46 AM (#130233)
Subject: Trailer Tire Wear
I was looking at a used trailer and noticed that ALL 4 tires were worn on both inside and outside edges while the center treads were still good.  Is this just due to incorrect tire pressure or possiably another problem?
Thanks!
Posted 2011-02-14 7:54 AM (#130234 - in reply to #130233)
Subject: RE: Trailer Tire Wear
It may be possible the pressure was too low and/or they did alot of sharp turning on a hard surface. Overloading the tires will result in the same If so, there just may be some hidden/unseen sidewall damage.
SunChick
Reg. Feb 2011
Posted 2011-02-14 8:18 AM (#130239 - in reply to #130233)
Retento...  YOU are the MAN!
Thanks!
lesliemal
Reg. Sep 2007
Posted 2011-02-14 11:23 AM (#130253 - in reply to #130233)
Make sure what you are seeing is actually tire wear. I put a set of brand new Goodyear G614 tires on my trailer and the edges of the tires do not have tread making them appear to be worn.
