Roof sealants
Last activity 2011-02-14 11:10 AM
3 replies, 3834 views
Adventurer
Reg. Feb 2011
Posted 2011-02-13 10:17 AM (#130193)
Subject: Roof sealants
I have a steel trailer and am looking for the best product to seal and protect the roof. The trailer sits outside all the time. I want it to be white also to help with the heat.
hornet
Posted 2011-02-13 12:26 PM (#130197 - in reply to #130193)
Subject: RE: Roof sealants
Many years ago I painted a product called Kool Seal on my first trailer. It stays flexible so it doesn't crack with the expansion and contraction of the metal. I was very satisfied with the ease of application and how it held up. It also helped with the temperature inside the trailer.
http://www.koolseal.com/home.asp
Adventurer
Reg. Feb 2011
Posted 2011-02-13 7:25 PM (#130212 - in reply to #130193)
Looks like a good product, any one else with any recomendations?
Posted 2011-02-14 11:10 AM (#130252 - in reply to #130193)
If the roof doesn't leak and it's not rusty, a good oil based white paint will provide the reflectivity you need to reduce the interior temps. If you feel your trailer needs a sealant coating, elastomeric products available from many sources work well and are long lasting.
I used the Kool seal product on a steel trailer I had. It failed in a dismally short time, and had to be completely sanded off before I could recoat with a marine grade paint. It was a mistake that I won't again repeat.
