Purchase of a 1996 4 Star - need advice
Last activity 2011-02-12 8:10 AM
15 replies, 13284 views
kahuck1a
Reg. Apr 2010
Posted 2011-02-10 6:07 PM (#130090)
Subject: Purchase of a 1996 4 Star - need advice
Hi all,
I have run across a 1996 4 Star 3h Gooseneck.  I was never going to consider buying something of that age but it appears to be in really good shape.  I have not seen it in person yet.   It looks like it needs to be acid washed.  It's pretty dull but the inside horse area looks clean.  Can a trailer of that age be made shiny again?  The trailer has the old style heavy duty mats that run all the way up the wall.  It looks like it's built like tank.  I wanted your advice on things I should look when buying an older trailer.  Also, what are your thoughts about resale value?  Do trailers ever become "worthless" after a certain age and then you just can't get rid of them? Is it the scrap yard at that point?
Regards,
Kim
kahuck1a
Reg. Apr 2010
Posted 2011-02-10 6:15 PM (#130091 - in reply to #130090)
Subject: RE: Purchase of a 1996 4 Star - need advice
Starting a checklist for things to check for:
1.  Axles (how do I check those; what am I looking for)
2.  Brakes
3.  Coupler (not sure what I should look for there)
What else?
Posted 2011-02-10 6:24 PM (#130092 - in reply to #130090)
4-Star trailers seem to hold their value very well. The older trailers look to be built a little heavier than the newer models. Be sure to check under the mats really good for pitting and any signs of corrosion. That trailer is 15 years old and there's no way to tell what kind of maintenance has been done until the mats are out and the floor scrubbed clean. Here's a 1999 that looks like it just had a good acid bath...!! All nice and shiny again.
http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=295117
<script> window.setTimeout("watermark()",50);
kahuck1a
Reg. Apr 2010
Posted 2011-02-10 6:52 PM (#130093 - in reply to #130092)
Thanks!
I will add:  "floor corrosion under mats" to the list.
P.S.  I saw that trailer and thought very strongly about it.  It's really nice and I like the escape door.  The one I'm looking at doesn't have the escape door but it does have the same rear door/ramp configuration. Probably by the time I got done with tax, tag and title, it wouldn't be worth it but it certainly is a nice trailer.  That's another subject.
crowleysridgegirl
Reg. Apr 2005
Posted 2011-02-10 7:12 PM (#130094 - in reply to #130093)
2000500100
It depends on what you pay for it.We lucked out on a really nice 2000 4H 4Star similar to the one that Rentento posted the picture of,only,ours does not have a ramp.it has an escape door.The only thing wrong with it was: the A/C unit did not work.We gave 10K for it and did backflips all the way to pick it up.we got a real deal on that trailer,and,when I finished acid washing it with Streakmaster,it looked new.I don't know how to post a picture on here or I would post one.a trailer like 4Star will always hold a good value if it's been cared for properly and doesn't have major floor corrosion.It's going to have some,however,bear that in mind.Maybe it will work out for you.
crowleysridgegirl
Reg. Apr 2005
Posted 2011-02-10 7:15 PM (#130095 - in reply to #130094)
2000500100
PS: according to what the one Rentento posted is selling for,I'd say we DID get a steal on ours.We just lucked out.This is about the average asking price for a trailer like this.
kahuck1a
Reg. Apr 2010
Posted 2011-02-10 8:31 PM (#130100 - in reply to #130094)
They are asking 11,000.00.   I thought that sounded a bit high but wasn't sure without seeing it in person.
Spin Doctor
Reg. Nov 2008
Posted 2011-02-10 8:33 PM (#130101 - in reply to #130090)
To me it depends if you can deal with a few little issues that will pop up. Such things as the moulding, window seals, wheel seals, chaulking, stripping, (most things made out of rubber/plastic) may have become brittle and might need replaced. If it has set outside, to me that is more important than the age. If stored inside, it sure keeps the UV rays from destroying these things. IF you can deal with the little things and can replace/repair them yourself, and if all the items the other posters look good, I would go for it.
Posted 2011-02-10 11:01 PM (#130111 - in reply to #130090)
It's very important that you check all the windows and doors for integrity and operation, along with the hinges, latches and all the attaching hardware. Many manufacturers change these items over the years, and if they are damaged, they may be difficult or impossible to replace. Ask for the keys and try them in the locks.
Another inspection should be made under the rear most section of the trailer. The rear cross member is welded /riveted at each end to the side rails. When ever a trailer is dragged on a rough road, these joints and structure are subject to damage.
You've already added this to your check list, but I have to emphasise its importance. Inspect the aluminum floor for corrosion. 4Star uses a sheet flooring. It may be dented and somewhat flexible. That's OK. Any holes, small piles or streaks of dark gray or whitish powder, should be carefully scrutinised. The underside of the flooring should also be carefully inspected. If any corrosion is found, these problems, if moderate, can be addressed and repaired.
You can check how well the axles are functioning, by looking at the wear patterns on the tires. If they are worn evenly across the tire's surface, you can assume the axles aren't bent or knocked out of alignment. The tires may have more wear in the center or both outside areas. This only indicates abnormal tire pressures. If they have cupping on the thread, or are worn bald on one side and not the other, there is an alignment problem which will require mainenance to repair.
Very soon after your purchase, the wheels should be pulled, the brakes inspected and the wheel bearings cleaned, inspected, changed if necessary, repacked and reinstalled. The brakes and bearings are some of the most critical maintenance items you should address.
The tires should be inspected for wear and their age determined. If they have to be replaced, you can expect to spend $175-$250 per tire. (E range 16" LT) They should be replaced regardless of wear, after 6 or 7 years of age.
The jack should be inspected for proper operation and greased. This is a maintenance item often missed by many owners.
This trailer already has depreciated almost as much as it's going to. Acid washed, the mechanics up to snuff, everything working, you could probably sell it in five years for about what you are now paying for it. A ten or fifteen year old trailer has taken a majority of the depreciation. It's value then on, will be determined primarily upon its condition and visual appeal. As long as it looks and operates well, there is no scrap heap in its future.
kahuck1a
Reg. Apr 2010
Posted 2011-02-11 6:57 AM (#130117 - in reply to #130090)
Thanks so much you guys!  You have mentioned some stuff that I never thought about.
Here is the list now:
1.  Axles - check wear pattern on tires; even on both sides of trailer?  Look for balding and cupping.
2.  Brakes/Wheels/Wheel bearings - inspect, cleaned, repacked
3.  Floor - above and below - corrosion via holes, piles or streaks of dark gray or whitish powder; some dents and some flexibility ok.
4.  Rubber/plastic items inside and out - moulding, windows seals,  stripping, chaulking
5.  Windows & doors - integrity and operation of (do keys work in locks)
6.  Hinges, latches & attaching hardware
7.  Rear cross member at each end of side rails-check welds & rivets and overall cross member for joint and structure damage, etc.
8.  Tires - dry rot, wear patterns, tread thickness
9.  Jack - greased and operational
10.  Coupler - movable
11.  Electrical
Anything else I should add to the list?
If an axle is found to be out of alignment, what does it take to fix that problem?  Is it expensive?
Is it difficult or expensive to fix floor corrosion?  How much corrosion is too much?
Best way to check for roof or other leaks?
How will I know which manufacturers have changed their hardware to the point that it is not replaceable on older trailers?  Is there a list somewhere?
Should I look at the axles themselves?  Any particular spots I should check?
Electrical - anything in particular there?
Thanks again.  I appreciate the wealth of knowledge.
Kim
pinkmouse
Reg. Jan 2009
Posted 2011-02-11 8:07 AM (#130118 - in reply to #130090)
I purchased an even older 4 Star last year - a 1992 model.  I have been very happy with it.  The only thing I have had to repair is one of the T-style door latches. All of the rubber is still good. The first thing I did was take it to get new tires (they were the originals!) and have the bearings packed.  I am adding LQ to the trailer and in my research I have found that I am able to get most of the parts for the trailer if I would ever need them.
One thing you might do while you are looking at the trailer (if it is at their home) is to look around and see if the home and property is well maintained.  That will give you a good indication of how well the trailer was taken care of.  Years ago I sold a car to someone who did not even bother to drive it - when I asked him why he would do that he said that based on how my property looked he was pretty sure that I had taken care of the car in the same manner.  That really stuck with me
If you follow pricing for high end trailers, they really hold their value.
JacciB
Reg. Nov 2006
Posted 2011-02-11 9:03 AM (#130125 - in reply to #130090)
10010010025
We just traded our 1997 4 star and got what we paid for it 3 years ago.  The only reason we sold it was to upgrade to a 3 horse with larger living quarters.
SunChick
Reg. Feb 2011
Posted 2011-02-11 9:35 PM (#130157 - in reply to #130125)
I have a 1993 4 Star 2 horse bumper pull!  Since that time I have also have 5+ LQ trailers of various brands.
Long story short, I still have this trailer for a reason......  You can't tear it up.  I did send it into the factory in OK City last year, with the same concerns as you, resale value.  I had new axles, wiring, striping, light covers....  Just the whole thing gone over (2,00.00).  The result, only 1 crack that needed to be welded!  There was even the original guys there that built it still there!  Now it might be just them talking, but according to them, if you keep your records of service, you would be surprised on what it's value would be.
If you don't mind a older trailer, 4Star would be probably the only brand to go with.
kahuck1a
Reg. Apr 2010
Posted 2011-02-12 7:23 AM (#130169 - in reply to #130090)
Subject: RE: Looked at the 1996 4 Star - need advice
I have seen the trailer in person now. It is in very good shape structurally. In fact, I was pretty impressed. Crawled in, over and under. The coupler needs to be replaced. Not sure how expensive that is.
The biggest concern that I see with it is it doesn't have drop down bars on the head side windows. Got to have that in FL. The horses would roast without it even adding fans. I don't care for the aftermarket window that velcro or zipper. Been there, done that. I don't feel as though they give the same air flow and they are a pain for me. Does anyone know if adding drop down bars is a possiblity and is it expensive? The escape door has a sliding window and it would be nice to make that a drop down too. Not sure it's worth the monies and might be better off to wait and find something else.
Thanks.
horsey1
Reg. Dec 2004
Posted 2011-02-12 7:51 AM (#130172 - in reply to #130090)
On the bars you have two choice- Have someone local fabricate you something that will probably be permenantly mounted, or check with your local 4 Star dealer about factory bars/hinges/etc. To add a drop in the escape- with enough time & money anything is possible. For that you'll need more money than time...!
brushycreekranch
Reg. Jun 2006
Posted 2011-02-12 8:10 AM (#130174 - in reply to #130090)
500100100100100
I had a 4 Star dealer add the drop bars to a trailer for $200 per window. I wouldn't waste money on trying to add a drop door to the escape  unless you plan to carry 3 horses every single time. If so, it will be $$$.  If not, you would more than likely use the front stall for hay, feed, etc which means more than likely the drop would be up anyway. I find that a must have for me is drop doors all the way around since I travel alot.
