Weird elec. problem
Last activity 2011-02-09 4:26 AM
6 replies, 4848 views
j&j
Reg. Oct 2005
Posted 2011-02-02 8:31 PM (#129704)
Subject: Weird elec. problem
We had a blizzard going through so the day before I wanted to check the LQ to make sure it was charged.If we lost power to the house I thought we could camp in it for a few days. We have a Battery Minder on it so I turned on an interior light to make sure we had power. Nothing. Well, I though maybe the plug wasn't in all the way, checked those and left it hooked up to the Battery Minder. I also checked all the camper fuses. They were ok. Came back later and still no lights. So I plugged it into the land line. Still no lights. I know the receptacle was working because the Battery Minder had lights. Today after the blizzard I tried it again. Lights! So what was the problem and will it happen again?
Judy
Posted 2011-02-02 9:39 PM (#129709 - in reply to #129704)
Subject: RE: Weird elec. problem
Did you unplug your battery minder, when you lost house power?
Edited by PaulChristenson 2011-02-02 9:40 PM
j&j
Reg. Oct 2005
Posted 2011-02-03 10:39 AM (#129728 - in reply to #129704)
No, we never lost power. I was just preparing in case we did.
Judy
docgj
Reg. Oct 2009
Posted 2011-02-03 12:32 PM (#129730 - in reply to #129704)
I suspect that you have a loose ground. The wind from the storm probably rocked the trailer allowing it to make contact again. Sometimes they are hard to find. I would start with the connections at the battery and trace till I found the bad one.
docgj
docgj
Reg. Oct 2009
Posted 2011-02-07 5:18 AM (#129856 - in reply to #129704)
j & j,
Did you find the fix to your problem?
docgj
j&j
Reg. Oct 2005
Posted 2011-02-07 5:28 PM (#129892 - in reply to #129704)
Well, it fixed itself. I believe that if something breaks by itself, if you wait long enough, it fixes itself!
Seriously, I think the battery minder was hooked up to the trailer batteries and was not plugged into the wall receptacle tight and it was off for a while. I am not sure what that does to the batteries, but everything seems to be working fine. I charged the batteries from the land line and they work. Now I have plugged the BM back in and it is on "maintaining". I hope I have not damaged anything.
Judy
docgj
Reg. Oct 2009
Posted 2011-02-09 4:26 AM (#129957 - in reply to #129704)
Glad it fixed itself. Sounds like you found the problem. Batteries probably were just run down.
docgj
