Another Mega cab question/Advice Sorry!
Last activity 2011-01-21 12:39 PM
1 replies, 3745 views
DAE
Reg. Oct 2009
Posted 2011-01-21 7:18 AM (#129104)
Subject: Another Mega cab question/Advice Sorry!
Need an opinion(s) from those who have Megacabs.
I have a 2500 Dodge Megacab (not long bed) and have to decide between 2 trailers - Both 20ft.  Difference is the featherlite is aluminum and square nose and titan is steel with tapered nose.  I prefer the Featherlite, but after reading previously posted comments I am concerned about hitting the truck frame/window/etc.  Will the hitch extension fix this sitution on most turns?  Which one will I need or work best?  What about placement of hitch?  or would I be better off going with the tapered nose trailer even though it is steel (not necessarily the one I want but will adapt) but still a good trailer.    Also, never having pulled a tapered nose trailer before does it pull different (wind resistance/etc.) than a square nose trailer?   Any insight would be helpful.  Thank you in advance for your help.
genebob
Reg. Nov 2007
Posted 2011-01-21 12:39 PM (#129122 - in reply to #129104)
Subject: RE: Another Mega cab question/Advice Sorry!
How wide is the Featherlite? If it is 7' there should be no problem. Most of the Featherlites do have a tapered nose, even though they are flat in the front. The best way to be sure, since you already have the truck, is to go hook on and try it.
