aluminum v stainless steel: need advice
Last activity 2011-01-17 7:45 PM
4 replies, 6104 views
baytraks
Reg. Jan 2011
Posted 2011-01-17 4:51 PM (#128985)
Subject: aluminum v stainless steel: need advice
While looking for an aluminum goose neck trailer to replace my 1994 steel trailer, I stumbled across a trailer with a steel frame and stainless steel skin.
I was looking at aluminum for longevity. Would I get the same longevity from stainless steel on a steel frame?
Thanks for any words of wisdom or experience you can share!
Posted 2011-01-17 5:19 PM (#128986 - in reply to #128985)
Subject: RE: aluminum v stainless steel: need advice
Originally written by baytraks on 2011-01-17 5:51 PM
While looking for an aluminum goose neck trailer to replace my 1994 steel trailer, I stumbled across a trailer with a steel frame and stainless steel skin. I was looking at aluminum for longevity. Would I get the same longevity from stainless steel on a steel frame?Thanks for any words of wisdom or experience you can share!
The aluminum trailer should last longer... http://upload.wikimedia.org/wikipedia/en/thumb/7/7d/Stainless-steel... Notice what happens when stainless steel and mild steel contact one another, without the benefit of galvanic corrosion protection...
Edited by PaulChristenson 2011-01-17 5:21 PM
Posted 2011-01-17 5:21 PM (#128987 - in reply to #128985)
Probably not and the trailer will much heavier than an "all aluminum" trailer. Those corogated stainless steel sheets are heavy and a steel frame is a steel frame no matter what the outer skin might be. Then there's some maintenance issues with that polished stainless. It all nice and shiny but requires proper maintenance to keep it looking that way, it has a tendency to streak.... Welcome to HTW...!!
Edited by retento 2011-01-17 5:24 PM
baytraks
Reg. Jan 2011
Posted 2011-01-17 5:36 PM (#128988 - in reply to #128985)
Thank you both very much; not the answer I wanted (it's a beautiful trailer!!), but likely the answer I needed.
tico
Reg. Jan 2009
Posted 2011-01-17 7:45 PM (#128992 - in reply to #128985)
I have a hawk trailer which is a steel frame aluminum skin and never had a problem with it. So far so good no complains, I wouldn't eliminate them it is my second one and I didn't have issues with my first one either.
