Gooseneck Hitch
Last activity 2011-03-04 7:15 PM
7 replies, 6647 views
endurance_racer
Reg. Nov 2009
Posted 2010-12-27 8:37 PM (#128308)
Subject: Gooseneck Hitch
Has anyone ever used the 'Flip Over' Hitches like these-http://www.gooseneckpopuphitch.com/flipovergooseneckhitchJust wondering how people like them compared to Draw-Tite flip over hitches?...Or the similar? Thanks
ellisor
Reg. Oct 2010
Posted 2010-12-27 9:05 PM (#128310 - in reply to #128308)
Subject: RE: Gooseneck Hitch
I've got a B&W Turn over, http://www.turnoverball.com/turnover.asp. Next ones I buy will be the same.
Posted 2010-12-28 1:15 AM (#128311 - in reply to #128308)
B+W too  Going on ten years of use ...  Simple and reliable
Posted 2010-12-28 1:33 AM (#128312 - in reply to #128308)
http://www.draw-tite.com/content/products.aspx?lvl=2&parentid=1800&... I like the fact that they have extension options 19306 1" High Rise, 2-5/16" Ball for Under-Bed Gooseneck Heads (Do Not Store Inverted In Head)
19307 3" Ball for Under-bed Gooseneck Heads (Do Not Store Inverted In Head)
19308 5" Offset Extension, 2-5/16" Ball for Under-bed Gooseneck Heads (Do Not Store Inverted In Head)
terri s
Posted 2010-12-28 7:05 AM (#128313 - in reply to #128308)
500100100100
I have a pop-up hitch and have for many years. It is a fine hitch, except...mine (and I'm on my second one) is not as easy to drop and raise as the ads would have you believe. It doesn't take much crud around the hitch to make the ball difficult to drop and the positioning of the handle next to the tire is very awkward. I drive a half-ton Chevy, the positioning may be different on different makes of trucks. We tend to leave the ball up all the time and it is a two person job to raise or lower it. Not sure I'd buy another one but they are made 30 miles from where I live and they seemed perfect at the time. Again, nothing wrong with them but if you really need to raise and lower your ball often, I'd look at something else.
ETA-I should have read further, I have the pop-up, not the flip over. Also, you cannot fault their customer service. When my first hitch jammed and even my mechanic couldn't get it to "pop" they replaced it without question, and several months later.
Edited by terri s 2010-12-28 7:07 AM
califhorseman
Reg. Feb 2008
Posted 2010-12-28 9:41 AM (#128315 - in reply to #128308)
Have B&W just have to keep it lubed.
gonzo1066
Reg. Oct 2010
Posted 2011-01-02 9:21 PM (#128457 - in reply to #128308)
I have the UniGoose hitch in both my trucks.  Very stout well engeneered hitch.   There are no levers to get salted sanded and not work.
camper101
Reg. Feb 2011
Posted 2011-03-04 7:15 PM (#131185 - in reply to #128308)
i have this curtquick goose gooseneck cheap trailer hitch. What i like about this hitch is it release convenience for the driver by eliminating the need to climb into the pickup bed to raise or lower the ball.
