06 dodge question
Last activity 2010-12-27 6:54 PM
2 replies, 3562 views
brew26
Reg. May 2009
Posted 2010-12-27 12:35 PM (#128302)
Subject: 06 dodge question
I have a 06 cummins and it doesn't blow the warmest air in the world. I put cardboard in front of the grill still not the warmest it has 44,000 miles next thought was the thermostat is going out. Only other thing I haven't checked is the radiator fluid to see what cold it is rated for. North East mt= cold in the winter.
hogtownboss
Posted 2010-12-27 3:11 PM (#128304 - in reply to #128302)
Subject: RE: 06 dodge question
10001001001002525
Originally written by brew26 on 2010-12-27 12:35 PM
I would check to see what the rating shows first and make sure the radiator is full.  If the above is fine I'm thinking the heater control valve is going bad.  With the truck running and the a/c on move the temp control and see it the air gets hot or just warm.  If just warm then the conteol valve is bad.
wyndancer
Reg. Apr 2007
Posted 2010-12-27 6:54 PM (#128305 - in reply to #128302)
Check the recirculation air door in the air box. My 2006 Dodge 1500 didn't warm up, or cool much. I poked around on the internet and found out about this very common problem. What happens is the air door breaks off, falls on top of the blower fan air intake, and blocks the air flow through the HVAC box.
