Disadvantage of Using Stable Mats-Can harm Horses
Last activity 2011-01-17 4:07 PM
6 replies, 6569 views
arackathara
Reg. Dec 2010
Posted 2010-12-15 11:29 PM (#128070)
Subject: Disadvantage of Using Stable Mats-Can harm Horses
Stable Mat floors are generally made up of a number of individual ramp mats. Urine can drain through the cracks when the mats are joined together. Unless one periodically cleans under the mats, or there is good drainage under the mats, the urine can build up under the Stable mats. The urine then breaks down, releasing ammonia (an unhealthy and unpleasant smelling gas) and odours. 40
Posted 2011-01-02 7:18 PM (#128452 - in reply to #128070)
Subject: RE: Disadvantage of Using Stable Mats-Can harm Horses
Originally written by arackathara on 2010-12-15 11:29 PMStable Mat floors are generally made up of a number of individual ramp mats. Urine can drain through the cracks when the mats are joined together. Unless one periodically cleans under the mats, or there is good drainage under the mats, the urine can build up under the Stable mats. The urine then breaks down, releasing ammonia (an unhealthy and unpleasant smelling gas) and odours. 40
Treatment is relatively simple... http://research.vet.upenn.edu/Portals/49/Lab%20Publications/96Effec... http://www.thehorse.com/ViewArticle.aspx?ID=15077
Edited by PaulChristenson 2011-01-02 7:20 PM
crowleysridgegirl
Reg. Apr 2005
Posted 2011-01-09 11:57 AM (#128701 - in reply to #128452)
2000500100
is there a "brand" or common name for that,Paul? Yeah,that was kind of a flat statement about the ammonia odor that I pretty much think is common knowledge among horse owners who stable.
Edited by crowleysridgegirl 2011-01-09 11:59 AM
Posted 2011-01-12 1:42 AM (#128824 - in reply to #128701)
Originally written by crowleysridgegirl on 2011-01-09 12:57 PM
No...but you can also use Stall Dry... http://www.absorbentproductsltd.com/stalldry_canada.htm
farmbabe
Posted 2011-01-12 9:32 AM (#128831 - in reply to #128070)
1000500100100
Although the horses are not stabled 24/7 on a regular basis( generally only in the spring summer)...I have had mats in the stalls for year....YEARS..never moved them and cleaned them yet I have no ammonia odors unless the bedding has not been changed ( and I do clean them everyday they are stalled) Other than the sand we put down to level the dirt floors, there is no real drainage to speak of. I had MORE problems with ammonia odors prior to the mats which is one of the reasons for them..that and the stalls are much easier to clean.
crowleysridgegirl
Reg. Apr 2005
Posted 2011-01-14 9:11 AM (#128894 - in reply to #128824)
2000500100
Thanks,Paul.I've heard from others that Stall Dry is an excellent product.
brushycreekranch
Reg. Jun 2006
Posted 2011-01-17 4:07 PM (#128984 - in reply to #128070)
500100100100100
We have vulcanized rubber vet mats that are "glued" together at the seams. We have NO odor whatsoever, unless, stalls are dirty. But, we still sprinkle PDZ on any wet spot on top of the mat as a precaution. Even though, our stalls are stripped and sanitized on a regular basis. Ammonia can reak havoc on their lungs.
