How to tack down mats in trailer?
Last activity 2010-12-15 1:27 PM
15 replies, 9679 views
horsepowerhaven
Reg. Dec 2010
Posted 2010-12-06 11:19 AM (#127830)
Subject: How to tack down mats in trailer?
Does anyone have any suggestions on how to stop my mats from sliding around in my trailer? They used to fit real tight and after I had the wood floor replaced and sealed with weatherproofer, they shift and slide.
This is a 2 horse slant and there are notches for the beams, etc. but it isn't enough to hold the mats in place.
I'd like to tack them down yet be able to remove them to pressure wash the floor.
Any ideas?
Posted 2010-12-06 11:34 AM (#127831 - in reply to #127830)
Subject: RE: How to tack down mats in trailer?
Counter sunk screws in each corner
horsepowerhaven
Reg. Dec 2010
Posted 2010-12-06 11:50 AM (#127832 - in reply to #127830)
How big of screws (Thickness, I can measure for length)? And is this safe for the horses?
Someone else told me it isn't safe to tack them down, which seems silly to me.
cutter99
Reg. Sep 2007
Posted 2010-12-06 1:40 PM (#127836 - in reply to #127830)
10010010010025
I think Gard means counter sunk for the horse's safety. I would think a loose slipping mat would be more of an issue than one that is tacked down.
Posted 2010-12-06 2:57 PM (#127837 - in reply to #127832)
Originally written by horsepowerhaven on 2010-12-06 12:50 PM
How big of screws (Thickness, I can measure for length)? And is this safe for the horses? Someone else told me it isn't safe to tack them down, which seems silly to me.
#10 stainless, 1 3/4" long, install until flush. As Cutter expained, a slipping mat is dangerous when a horse looses its footing. Definately silly
Spin Doctor
Reg. Nov 2008
Posted 2010-12-06 4:40 PM (#127838 - in reply to #127830)
Just guessing, but I wonder if the sealant you used turned the floor abnormally slick? We used to treat trailer floors with a sealant and the deck/floor got really slick. A covering of pea gravel/sand typically cured it. It might work to just put some small gravel/sand in between the mats and the floor....???
horsepowerhaven
Reg. Dec 2010
Posted 2010-12-06 10:23 PM (#127844 - in reply to #127830)
Thanks! Someone else told me that I need to put a bunch of screws in as having them only in the corners would just tear the mats. They are really thick mats, so I don't see this happening very easily.
Sand in between--yes could potentially roughen up the sealant on the wood, but I think it would make the mats slip more. One of my horses got some wood chips underneath them and they slid more than usual.
Thanks! I'll give this a try for sure.
Posted 2010-12-07 8:49 AM (#127848 - in reply to #127830)
If you have a trailer with thin, less dense mats, you might want to use different attaching hardware. Instead of #10 counter sunk 1 3/4" long screws, purchase #10 stainless round head screws 1 1/2" in length. Aso purchase an equal number of the larger stainless "fender" washers, and place one under the head of each screw.
When the pilot holes are drilled for the screws, place them about 4" inside the mats' outer perimeter. These revisions will lessen the chances of the screws being pulled out of the lighter weight mats.
terri s
Posted 2010-12-07 9:05 AM (#127849 - in reply to #127830)
500100100100
What about putting a textured coating on top of the weather proofing? Like a roof sealant or the duplicolor stuff?
Posted 2010-12-07 9:27 AM (#127850 - in reply to #127849)
The bed liner material would probably be as slippery as the sealant and isn't made for wood applications, so bonding might be an issue. A rubberized type of roof coating like an elastomeric product would offer a more"sticky" surface, but I don't know how much friction it would have when it becomes wet. I wonder if the sandpaper like, non skid material used on steps, could be bonded to the flooring with polyurethane construction adhesive?
The srews could be installed in a couple of minutes. Only the two fasteners on the butt end have to be removed, and the mats rolled to the head side, whenever it's necessary to flush under the mats. A battery powered drill can remove the screws in seconds. The mat can't move when it is physically attached.
I've never had mats that moved, and if they're cut to size, wonder how far out of place they can migrate?
Posted 2010-12-07 10:55 AM (#127853 - in reply to #127830)
..... You going to "un-tack" those mats everytime you clean out that trailer? If I had mats that migrated as you say, I would do away with them and bed heavily with pine shavings.
Posted 2010-12-07 11:29 AM (#127856 - in reply to #127853)
If you want to entirely stop messing with the mats, grab your pneumatic roofing nailer, insert a new roll of 1 3/4" nails into the magazine, and fire them all off around the perimeter of the mats. The entire 120 nail roll per mat is a good start.
Then, because you're not really sure these will hold, grab your 21 degree, full head, pneumatic framing gun laying on the work bench. Crank up the compressor's regulator to a comfortable hundred PSI or so, grab three or four clips of 3 1/4" nails, and go back to the mats. Shoot at least one nail between each of the roofing nails you previously installed, and then another clip anywhere else you choose, just because it feels so good to shoot the gun.
When you have finished installing these nails, and again because you're still not sure if the mat will stay in place, grab your 24 oz framing hammer and crawl under the trailer. You will see the tails of all the framing nails you shot, sticking down through the wooden flooring. With your hammer, bend each one upward until it's flush with the bottom of the flooring. If you don't, all your barn cats and small dogs will have tracks in their fur that will resemble  Mohawk hair cuts.
Now you can be reasonably certain that the mats won't move enough to bother your horses' footing.
Edited by gard 2010-12-07 11:33 AM
pinkmouse
Reg. Jan 2009
Posted 2010-12-07 11:51 AM (#127857 - in reply to #127830)
LOL!!!!
Seriously, my aluminum floor is really slippery, but my mats don't move at all.  They are heavy stall type mats that are cut to fit the floor and have only about 1/2" of play from side to side/front to back.
I also have a wood floor in my other trailer - super slippery as well.  The heavy mats in there don't move either - they are also properly fitted to the corners/angles of the floor.  And the horses that go in that trailer are quite an active bunch.
Would a thicker mat help?
crowleysridgegirl
Reg. Apr 2005
Posted 2010-12-14 1:18 PM (#128038 - in reply to #127856)
2000500100
IMO,if they are thick enough and cut tightly enough to fit,there's just not a lot of room for them to go even if they do move around somewhat.
windy
Reg. Oct 2004
Posted 2010-12-15 10:54 AM (#128057 - in reply to #127856)
Originally written by gard on 2010-12-07 10:29 AM
Ha Ha! Glad you're back, Gard!
my3horses
Posted 2010-12-15 1:27 PM (#128061 - in reply to #127830)
Not going to let husband see Gard's response. Pneumatic nail guns are what I got him for Christmas. I would hate for him to practice on the trailer--LOL!
