What type of pipe to use for water lines
Last activity 2010-12-07 4:49 PM
12 replies, 7856 views
ofletcher
Posted 2010-12-02 9:50 PM (#127725)
Subject: What type of pipe to use for water lines
what type of pipe should i use when plumbing out weekender for water will be exposed to some sun?  And where to get it?  hot and cold water to faucet inside LQ, shower fixture under goose and outlet for hose under goose.  Threre are so many choices your help is apreciated.  Thanks  Owen
wyndancer
Reg. Apr 2007
Posted 2010-12-03 8:16 AM (#127730 - in reply to #127725)
Subject: RE: What type of pipe to use for water lines
For the inside I'd use PEX...but think about soft copper for the outside stuff. I'm not sure about UV rays and PEX.
Posted 2010-12-03 10:47 AM (#127734 - in reply to #127725)
Sunlight degrades just about all plastics used for water lines.  If you do use plastic, a coating of paint will slow the degradation from sunlight.
ofletcher
Posted 2010-12-04 1:30 AM (#127755 - in reply to #127725)
there has got to be some type of plastic that is more uv stable, a friend told me of a black pipe that grainger sells but on their website they sell tons of black plastic pipe, just not sure what to use but don't think i'll use copper wouldn't the vibrations tear apart the joints???
wyndancer
Reg. Apr 2007
Posted 2010-12-04 11:49 AM (#127766 - in reply to #127725)
Lots of propane piping is done in soft copper in RV's and horse trailers.
SRWilson
Reg. Jul 2010
Posted 2010-12-04 5:41 PM (#127778 - in reply to #127725)
Most all of the RVs and tailers these days us a PEX type pipe/hose for the water system.  the grey and black water tanks  use black PVC type pipe.  The Black pipe is UV resistant and will not let the sunlight in to assist in the growth of bacteria and will cause issues and smells.  Copper could be a bit expensive depending on how much line you have to run but since it is all part of the trailer, if you sweat weld it correctly you shouldnt have any issues with joints pulling apart.
ofletcher
Posted 2010-12-06 10:34 PM (#127845 - in reply to #127725)
ok so it looks like you have got me convinced to use soft copper, i didn't know you could sweat them i thought it was only compression fittings?  right? or am i thinking funny?
I only need to run a foot or two inside past the bulkhead of the trailer so will be copper the whole way.
thanks for the info.
Owen.
Edited by ofletcher 2010-12-06 10:37 PM
wyndancer
Reg. Apr 2007
Posted 2010-12-07 7:09 AM (#127846 - in reply to #127725)
You could solder, go compression or flare.
Posted 2010-12-07 8:06 AM (#127847 - in reply to #127725)
Solder desn't work well when the pipe is subjected to vibration
Posted 2010-12-07 10:20 AM (#127851 - in reply to #127725)
Use the Pex plastic. More resistant to freezing than the copper.
Posted 2010-12-07 11:54 AM (#127858 - in reply to #127847)
Originally written by gard on 2010-12-07 5:06 AM
Working "well" is relative.  I've worked with many production machines with soldered copper joints. They operated and vibrated 24/7/365 for many years.   More vibration than a horse trailer's life.  The key is to support the piping to the frame yet allow differential expansion.
OP: Do drain the system for the winter or freeze protect the pipe.  Plastic or copper will burst when filled with freezing water.
horsey1
Reg. Dec 2004
Posted 2010-12-07 12:44 PM (#127862 - in reply to #127725)
Not to ask a silly question- but where exactly will your plumbing be exposed to the sun? I don't think I've seen a LQ or travel trailer where this is an issue? If it is all inside- I'd vote for the pex option. Now LP gas plumbing is a different story, but I assume we are talking potable water in this case.
Posted 2010-12-07 4:49 PM (#127865 - in reply to #127725)
Another vote for PEX...a plus, in case you have to do future repairs
