Question bout 2006 Dodge
Last activity 2010-11-19 2:56 PM
4 replies, 3758 views
brew26
Reg. May 2009
Posted 2010-11-18 12:42 PM (#127250)
Subject: Question bout 2006 Dodge
I have a 2006 Dodge Mega cab and when I start it and its just idling I will turn on lights they come on fine. But when I go to drive off the lights will get a little bit brighter when it idles up anybody have this. Not that I find it a problem just wierd.
Posted 2010-11-18 1:42 PM (#127251 - in reply to #127250)
Subject: RE: Question bout 2006 Dodge
When your engine is above idle, the alternator voltage will exceed your battery voltage. Any illuminated lights will show this difference.
brew26
Reg. May 2009
Posted 2010-11-18 2:06 PM (#127253 - in reply to #127250)
Makes sense thank you.
walbern1
Reg. Jul 2008
Posted 2010-11-18 4:18 PM (#127259 - in reply to #127250)
The Dodge (Cummins) diesels have a intake grid heater that pre-heats the air before it goes into the engine it draws a ton of power and will cause the lights to dim and brighten. Only usually happens at colder temps like say now.
jarmstrong
Reg. Mar 2009
Posted 2010-11-19 2:56 PM (#127296 - in reply to #127250)
Look at the amp gauge- it should be reading low while this is happening.when the heater is done cycling it will go up to normal, at least on my 03 it does, thats how long I let it warm up before going when cold out.
                                           Jerry
