Extending trailer?
Last activity 2010-11-04 5:34 PM
9 replies, 4670 views
pavetim
Reg. Nov 2010
Posted 2010-11-03 5:56 PM (#126633)
Subject: Extending trailer?
I have a 1995 hart 4 horse trailer with dressing room. I was thinking of extending the dressing room by 10 feet. I was wondering if anbody has an diagrams of the structure of the trailer so I would know what aluminum to buy, and also what is the trailer made of it looks like plywood covered in a white material. Is that right, and what is that white stuff?
adeberti
Reg. May 2007
Posted 2010-11-03 5:58 PM (#126634 - in reply to #126633)
Subject: RE: Extending trailer?
it seems like a lot of work....you will be adding a lot of weight which will probably require you to changes axles and tires: you might better off getting a new one
pavetim
Reg. Nov 2010
Posted 2010-11-03 6:00 PM (#126635 - in reply to #126633)
i'm not sure of the wt ratings but it has dual 8 lug axles on it already.
cutter99
Reg. Sep 2007
Posted 2010-11-03 7:04 PM (#126637 - in reply to #126633)
10010010010025
The white stuff would be FRP- fiberglass reinforced plywood. You could talk directly with Hart about modifying your trailer.
pavetim
Reg. Nov 2010
Posted 2010-11-03 7:27 PM (#126639 - in reply to #126633)
I emailed hart and see what they say I'ts just an idea I figure it shouldn't cost that much to extend it by 6-10ft, just a thought thats why I want to look into it. but right now I got some rotted wood where the air cond was leaking so have to figure out how to cut a big piece out and replace it. To me it looks like plywood with frp on top and bottom but i'll ask hart just to make sure thats what it is.
Posted 2010-11-03 7:31 PM (#126640 - in reply to #126633)
Welcome to the forum ...
 Your question is like asking the price of a 150 foot salling ship or a new Ferrari Testarossa.
"...If you have to ask, it's beyond your reach."
I admire your reach though... Can't spend for a built-in hot shower in my trailer so I built my own shower that does the same ...  Just takes a bit of setting up.
You likely would be better served buying another trailer with 10 foot dressing room.  Or by taking the trailer to a custom fab shop that can price your desires.
Tresvolte
Reg. Feb 2008
Posted 2010-11-04 7:38 AM (#126648 - in reply to #126633)
It sounds like it is FRP, like they said. It is basically a piece of plywood with fiberglass on each side.
IMO - Concerning extending the dressing room by 10', it wont be as feasible as you think. There are many things to think about;
Structure - it's kind of like making a 2x4 longer. You'll have to overlap a certain amount in order to maintain strength. With the aluminum extrusions, you can't just overlap for appearance, so you'll have to figure extra bracing inside and out.
Axles - not just if they are heavy enough, but distance from the coupler. It will make for a tongue heavy trailer just adding 10' to the front.
Price - Most manufacturers are charging somewhere around $500 per foot to add length to a trailer on an order. That will be cheap compared to dismantling an existing trailer and adding structure plus footage and then putting it all back together. IF, and that is a big if, you can find someone willing to take the liability and do it, with labor and additional bracing, it wouldn't surprise me to hear of a price from $10,000 to $15,000.
Resale value - While your trailer may hit a bigger market with the larger dressing room, it will not increase in value by what it costs you to do it. Unless you plan on keeping the trailer forever, I can't see the benefit in it. I can actually see it losing value due to being so heavily modified.
buyshadow
Reg. Jan 2009
Posted 2010-11-04 4:57 PM (#126666 - in reply to #126633)
Sent you a private message!
sinful
Posted 2010-11-04 5:20 PM (#126669 - in reply to #126666)
Originally written by buyshadow on 2010-11-04 4:57 PM
  Here we go again!
laurie
Reg. Jun 2004
Posted 2010-11-04 5:34 PM (#126671 - in reply to #126633)
10010010010025
I can't understand why someone would even think it would be safe and cost effective to customize something existing vs just selling and buying something already done that way from the factory. Now it's one thing if you worked in a frame shop so you would have an idea if it is feasible and costs associated with it and then you would have an idea of what it takes so these questions wouldn't even be asked.
