Clunk noise going through dips and over bumps
Last activity 2010-10-25 11:03 PM
7 replies, 8196 views
Peggy
Reg. Mar 2008
Posted 2010-10-24 8:03 PM (#126194)
Subject: Clunk noise going through dips and over bumps
Any suggestions on what is causing a clunk sound whenever the truck and trailer are not on level ground?  Truck is 2000 F350 V10, non-dually.  Trailer is 2000 Jamco, 4 horse with 5' short wall that's been hauled very little.  Hitch is B&W.  Truck does not make the noise when pulling the boat.  I've only hauled the trailer with a friend's truck once and can't remember if I heard the noise.  We drive very slow and careful...65 on highway is max.
Thanks in advance for input!
Posted 2010-10-24 8:55 PM (#126195 - in reply to #126194)
Subject: RE: Clunk noise going through dips and over bumps
Originally written by Peggy on 2010-10-24 9:03 PM
I would guess your boat is much less weight than your horse trailer and is a bumper pull rather than a gooseneck...Are you sure there's nothing in the bed? Hitches can rattle on bumps. Outside of that, check the rear shocks, calipers, springs, bump stops, and spare tire.Worse case scenario...is your hitch assembly loose???
Edited by PaulChristenson 2010-10-24 8:56 PM
Posted 2010-10-24 10:04 PM (#126198 - in reply to #126194)
 I assume the boat trailer hitch is a rear receiver, and the horse trailer is a bed mounted GN ball. I would think that if one were making noise and the other wasn't, the shared truck's suspension components wouldn't be an obvious culprit.
Like Paul said, it may be the GN hitch, particularly if it is retractable. It may be something as simple as loose bed bolts. Get a couple of people and rock the truck by pushing on the top of the bed from side to side. Get some people together and jump into the truck's bed. If they do a coordinated wave action, you may be able to produce some noise and discover what is loose.
With someone riding in the bed, drive down a rough road. Your passenger may be able to specifically hear the point from where the noise is originating.
BigT
Posted 2010-10-24 10:46 PM (#126199 - in reply to #126194)
Overload (helper) springs, maybe the damper is missing?
HERB
Reg. Jan 2010
Posted 2010-10-25 6:14 AM (#126200 - in reply to #126194)
I have a B&W hitch and often hear a bumping noise from the spring loaded u bolts from the safety chains.
wyndancer
Reg. Apr 2007
Posted 2010-10-25 7:45 AM (#126201 - in reply to #126194)
There are LOTS of bolts on a B&W hitch. For sure I'd check all the hardware.
hogtownboss
Posted 2010-10-25 9:45 PM (#126236 - in reply to #126194)
10001001001002525
Not only the B&W hitch will have some movement, but also check the bolts on the gooseneck hitch itself if equiped.  One of the trailers we had used a hitch pin type setup for the gooseneck adjustment and it always had movement and left us with an uneasy feeling.
Peggy
Reg. Mar 2008
Posted 2010-10-25 11:03 PM (#126242 - in reply to #126194)
Happy dance, Gard is back!!!!
Thanks for all the suggestions...hubby is going to round up some guys at work tomorrow and start shaking the truck.  And look for anything loose.  Our first GN and we feel like we're learning a foreign language.
Edited by Peggy 2010-10-25 11:06 PM
