Trailer wheel bearings question
Last activity 2010-10-16 11:27 AM
9 replies, 9217 views
Becky
Reg. Jul 2004
Posted 2010-10-15 10:38 AM (#125797)
Subject: Trailer wheel bearings question
How often should trailer wheel bearings be packed? I have one small bumper pull trailer that is pulled probably around 1000 miles per year. And a 3 horse gooseneck that is only pulled a few thousand miles per year.
Both trailers had the bearings packed 2 years ago.
I'm taking the small trailer in for other repair and I'm wondering if the bearings should be packed?
flyinghfarm
Posted 2010-10-15 11:16 AM (#125799 - in reply to #125797)
Subject: RE: Trailer wheel bearings question
1000100100
Good for peace of mind......not an expensive procedure for KNOWING all is in good repair..
flatlandfilly
Reg. Jun 2006
Posted 2010-10-15 11:35 AM (#125801 - in reply to #125799)
If it were me I would have bearings repacked on both after 2 years. Do the small trailer now because you are taking it in. The gooseneck might wait til spring if it doesn't get much use in the winter but no longer. It's like changing the oil in your truck. Needs to be done on a regular basis.
Like Flyinghfarm says good for peace of mind and not too expensive.
Posted 2010-10-15 2:00 PM (#125805 - in reply to #125797)
Check with your trailer or axle manfuacture for the recommended intervals.
A 1000 miles is nothing for mileage on bearings.  I've got over 2000 miles on my horse trailer since August.
I usually pull mine and repack them, check the brake linings  and tires every spring. It's not a difficult job.
Edited by Painted Horse 2010-10-15 2:02 PM
Posted 2010-10-15 3:27 PM (#125807 - in reply to #125797)
I re-packed the bearings every year with Synthetic Grease. And it's not so much because the bearings need it (they most likely do) but because it gives me a chance to inspect the brakes and bearings.
wyndancer
Reg. Apr 2007
Posted 2010-10-15 6:12 PM (#125811 - in reply to #125807)
Originally written by PaulChristenson on 2010-10-15 3:27 PM
The truth from Paul. The bearing grease isn't wearing out, but the shoes/magnets/springs could be. So for little added cost, the bearings get re-packed and new grease seals installed.
Edited by wyndancer 2010-10-15 6:13 PM
Jbsny
Reg. Apr 2004
Posted 2010-10-15 6:38 PM (#125812 - in reply to #125797)
10010010025
Also, I thought it was possible if the trailers sit a long time for the bearings to get flat spots?
Jbsny
Posted 2010-10-15 8:16 PM (#125814 - in reply to #125797)
If bearings got flat spots you would have to REPLACE them not REPACK them.
Repacking a bear means cleaning and repacking with fresh grease.
Edited by Painted Horse 2010-10-15 8:17 PM
Jbsny
Reg. Apr 2004
Posted 2010-10-15 8:27 PM (#125817 - in reply to #125797)
10010010025
Agreed there on replacing bearings that might have a flat spot, but since my trailers sit more than they go, I get them checked every year.
One of the race horse trainers I boarded with borrowed a trailer and during transit to KY, the bearings seized up and the axle came off the trailer.  Again, another reason I have mine checked.  I knew the owner of the trailer and I had seen it sitting in a field behind his house.  I guess he didn't know about checking bearings on trailers
Jbsny
Posted 2010-10-16 11:27 AM (#125828 - in reply to #125797)
One of the neat new features that Ford has put on it's 2011 SuperDuty trucks, is the ability to track multiple trailers.  In the command center you can enter up to 16 trailer descriptions. When you hook up the trailer, Go to the command center and select that trailer description. It will remember the brake settings and track the mileage for that trailer.
Now with this feature, I can look at mileage to determine maintenance instead of the calendar. Instead of saying once a year, I will do bearings, I can say, every 16,000 miles, I will repack them.  It's a neat feature and I bet you see it added to other trucks in the future.
