TV in LQ's
Last activity 2010-09-29 11:08 PM
16 replies, 9285 views
NTO
Reg. Jul 2010
Posted 2010-09-21 11:57 PM (#125105)
Subject: TV in LQ's
I have a TV with VCR player that is 9 years old so of course it doesn't work.
What set up do I have to get or would it be cheaper to buy a new TV?
Will a new TV work with my existing antennae?
Thanks!
RAF
Reg. Jan 2009
Posted 2010-09-22 6:40 AM (#125107 - in reply to #125105)
Subject: RE: TV in LQ's
Yes just buy a new TV your old ant. will work just fine
nobodyimportant
Reg. Jan 2010
Posted 2010-09-22 8:01 AM (#125108 - in reply to #125105)
Since you can only buy digital new, you should upgrade your antenna as well.  You could keep your old one, but you'll be happy that you switched.
hornet
Posted 2010-09-22 9:19 AM (#125113 - in reply to #125105)
Your old antenna will work just fine. Folks have made a lot of money off so called "digital antennas". The antenna knows no difference in analog or digital, it only cares about frequencies and will work fine with either signal format.
flyinghfarm
Posted 2010-09-22 11:01 AM (#125116 - in reply to #125105)
1000100100
My smaller flatscreen dgital TV works fine with my original (2001) batwing crankup antenna....
paintcrazytexan
Reg. Feb 2008
Posted 2010-09-22 12:22 PM (#125120 - in reply to #125116)
   Boy, I thought I was the only person left with a batwing antenna!
nobodyimportant
Reg. Jan 2010
Posted 2010-09-22 3:18 PM (#125123 - in reply to #125105)
"Generally, the same antenna that currently provides good quality reception on an analog TV set will also provide good DTV reception, but this is not always the case. The type of antenna you need for digital reception depends on several factors, including how far you are from the transmitting station, where your antenna is located and in which frequency band (VHF or UHF) the stations are that you want to watch."  from http://www.dtvanswers.com/dtv_antenna.html
The problem with the old batwing style is that they aren't always aimed right and you still have to "tune in" like before.  With a new digital antenna, most of which are omnidirectional, you won't have that problem.  Plus depending on how old the antenna the cable is older and won't handle the extra signal information.  Your picture quality won't be as good in certain situations.
hornet
Posted 2010-09-22 6:31 PM (#125126 - in reply to #125105)
Wrote by the same folks who said we'd see an improvement with digital tv, so far it's worse then analog and the antenna has nothing to do with it.The problem with omnidirectional antennas is that they are omnidirectional, which by nature do not have as much gain as the bat wing style that require "tuning". As for the cable, same goes with that as the antenna, as long as the cable is not damaged, it doesn't matter what kind of signal (analog or digital) you send down it, only the frequency.
Edited by hornet 2010-09-22 6:34 PM
Posted 2010-09-22 9:00 PM (#125136 - in reply to #125105)
Manual Tuninghttp://www.northerntool.com/shop/tools/product_200413258_200413258Automatic Tuninghttp://www.northerntool.com/shop/tools/product_200417163_200417163
hogtownboss
Posted 2010-09-22 10:03 PM (#125146 - in reply to #125105)
10001001001002525
Originally written by NTO on 2010-09-21 11:57 PM
Thanks!
If your around Texas and have not bought a new one yet, I have one we bought just before we bought our Sundowner and use it 1 time in our other trailer.  It is a 17" or 19" flat screen with a dvd player built in the side.  Only about 5" thick.
ponytammy
Posted 2010-09-23 1:19 PM (#125159 - in reply to #125105)
500100100252525
I wouldn't bother with the new TV setup. Every horse camp we go to, we cannot get a channel. Too far out for the signal to work through the trees etc. It works at home since we are closer to the city, but can't pull a signal at most remote wilderness locations. We use to be able to at least get one channel even if it was snowy with analog, but this new digital muck has limited our ability to receive a signal.
Unless you are going to be watching TV at horse shows near metropolitan locations, I'd spend the money on a cheap DVD player and a bunch of used DVD movies.
NTO
Reg. Jul 2010
Posted 2010-09-28 10:59 PM (#125308 - in reply to #125105)
Thanks for all the replies.
NTO
Reg. Jul 2010
Posted 2010-09-28 11:01 PM (#125309 - in reply to #125146)
Originally written by hogtownboss on 2010-09-22 10:03 PM
Thanks!
We live 45 miles NW of San Antonio.
Where are you at?
hogtownboss
Posted 2010-09-28 11:17 PM (#125310 - in reply to #125105)
10001001001002525
We live in Decatur and I work in Ft.Worth.....
sdlepalpm
Reg. Nov 2008
Posted 2010-09-29 10:08 PM (#125333 - in reply to #125310)
Most campgrounds we go to, there is no tv reception.  We watch movies on DVD  which our older tv has a dvd player built in.
NTO
Reg. Jul 2010
Posted 2010-09-29 11:06 PM (#125336 - in reply to #125105)
I use my trailer when I go to barrel races and I've always been able to get some stations.
NTO
Reg. Jul 2010
Posted 2010-09-29 11:08 PM (#125337 - in reply to #125310)
Originally written by hogtownboss on 2010-09-28 11:17 PM
It's almost 300 miles to Ft. Worth. It was worth a try. Thanks!
