hot wires
Last activity 2010-09-21 9:29 AM
9 replies, 5735 views
mud_dog
Reg. Dec 2004
Posted 2010-09-20 5:12 AM (#125028)
Subject: hot wires
I have a trail boss interior when I turn the lights on in the horse area I can smell wires smoking and the wires in fuse box is hot. Trailer is 2004 any suggestions.
Posted 2010-09-20 9:35 AM (#125042 - in reply to #125028)
Subject: RE: hot wires
Look for a light that isn't working. It sounds as if one of the light's hot wire is partially shorted to ground. You can try pulling the fuse and making sure the spade contacts are clean and not arcing.
If neither are a cause, you'll have to trace the wiring route, to find where the wire's insulation has chaffed against a rough edge of the metal. Look where the wire passes through drilled holes, and over the edges of extrusions for damaged insulation. If the location of the short isn't found, pull the fuse to prevent the possibility of a fire. You may have to then run a new source wire.
mud_dog
Reg. Dec 2004
Posted 2010-09-20 11:20 AM (#125049 - in reply to #125028)
The only wire getting hot is the ground wire in the fuse box I disconnected it and run a jumper to the frame and it still gets hot. No lights are out.
Posted 2010-09-20 1:24 PM (#125056 - in reply to #125049)
Originally written by mud_dog on 2010-09-20 11:20 AM
Do you mean that it is hot to the touch?? or electrically "hot" .. carrying current??
if the green or bare ground wire has power, then the black wire is leaking, touching, the body of the unit...and/or the neutral is not connected back to the panel
whh
Reg. Jan 2010
Posted 2010-09-20 3:11 PM (#125062 - in reply to #125028)
Sounds like there is a loose connection somewhere. Start at the fuse box or what ever you have and check every thing on that circuit.
mud_dog
Reg. Dec 2004
Posted 2010-09-20 6:17 PM (#125066 - in reply to #125028)
hot to the touch
Posted 2010-09-20 7:53 PM (#125072 - in reply to #125028)
If you've checked all the connections, consider the lights.  Did someone add more lights or changed the bulbs?  The fuse should prevent the overload but, that could have been up sized improperly too.
Posted 2010-09-20 7:56 PM (#125074 - in reply to #125028)
Need a clarification... Is the ground wire on the 12 volt DC system or the 120 AC system??
mud_dog
Reg. Dec 2004
Posted 2010-09-21 4:58 AM (#125084 - in reply to #125028)
12 volt
Posted 2010-09-21 9:29 AM (#125088 - in reply to #125028)
Try a jumper cable from the ground lug of the electrical panel to the neg batterry terminal.  This bypasses the hot ground wire completely.  Then turn on your lights.  If the wire doesn't heat, then the causes could be an internal break in the wire, a poor frame connection at either the battery or panel.
