trailer connections
Last activity 2010-09-15 7:51 AM
2 replies, 3828 views
jack4444
Reg. Nov 2009
Posted 2010-09-14 11:42 PM (#124882)
Subject: trailer connections
Has anyone had a problem with the wiring on the plug in of a Sundowner LQ not matching up with the wiring on a F350?  Since both ends are factory sealed it is not as easy as just removing a screw or two to change wires around.  Any suggestions?
Posted 2010-09-15 3:40 AM (#124883 - in reply to #124882)
Subject: RE: trailer connections
This may help...  http://www.horsetrailerworld.com/home/wiring.asp
Posted 2010-09-15 7:51 AM (#124884 - in reply to #124882)
Depending on how your LQ was finished... You might try accessing the terminal strip where the cord enters the trailer.  Switching the wires to match your truck is simple then.   In my Sundowner, the terminal strip is in the center of the nose, under a cover.
