Putting wall covering against metal??
Last activity 2010-09-13 11:26 AM
0 replies, 3427 views
Vegas
Posted 2010-09-13 11:26 AM (#124818)
Subject: Putting wall covering against metal??
Ok, I have a '95 Keifer horse trailer. The exterior walls in the dressing area are insulated already. To explain, there is the metal on the outside of the trailer, insulation, and then metal on the inside of the trailer. (Factory) So, basically all of the studs are inclosed between the two metals, and there is already factor insulation. It is a styrofoam lookind stuff. My question is..... Im doing a DIY LQ area and I'm not sure if I can screw or glue the paneling to the interior wall or do I have to frame the walls and then insulate again before I put up any wall covering on the inside? Wasnt sure if it would sweat or not?
