Towing with SUV
Last activity 2010-09-03 12:45 PM
4 replies, 4815 views
MargaretW
Reg. Sep 2010
Posted 2010-09-03 7:15 AM (#124331)
Subject: Towing with SUV
Hi all. I'm considering buying an SUV for normal driving but also as an additional tow vehicle for my 3H steel bp. What would you consider the best for towing/braking? And would it be recommended to install an anti-sway kit? Don't know much about those but I heard they are a good idea. Just wondering if they are necessary. Safety is first and foremost. Ease of use is secondary.I read that the Nissan Armada has the highest tow capacity but have also read that the GMC Denali is good.Opinions?
nobodyimportant
Reg. Jan 2010
Posted 2010-09-03 8:23 AM (#124334 - in reply to #124331)
Subject: RE: Towing with SUV
The Armada should have around 9500 lbs. of towing capacity, if it has a tow package.  If it doesn't, it's around 8000lbs.  I have a Titan, and found it to be very reliable when towing.  While it is still a 1/2 ton truck, it still should be enough for you to tow and stop your 3h bp.  Denali's should have around 8800lb capacity.  I personally don't know anyone who tows with one, so I have no opinion on that.
Regardless of what you choose, you do need to remember that you are "towing" everyone and everything thats inside your vehicle plus whatever is attached to your hitch.  Many people forget that.  You will also need to consider the topography of where you are towing when choosing  your tow vehicle.
Personally, I would know the weight of the bp, horses and people/stuff that will be riding in the vehicle and subtract that from your tow rating.  If you have less than 1000lbs difference, I wouldn't tow with it.  Being able to stop safely is very important.
nobodyimportant
Reg. Jan 2010
Posted 2010-09-03 8:32 AM (#124335 - in reply to #124334)
Ok, should have checked this before the last post (im an idiot).  Armada's have either 9000# (4WD) or 9100# (2WD).  Denali's range from 7600# to 8100#.  Probably wouldn't tow with one since, once loaded, you will be right at your max weight.
Posted 2010-09-03 11:52 AM (#124351 - in reply to #124331)
Originally written by MargaretW on 2010-09-03 8:15 AM
Hi all. I'm considering buying an SUV for normal driving but also as an additional tow vehicle for my 3H steel bp. What would you consider the best for towing/braking? And would it be recommended to install an anti-sway kit? . Just wondering if they are necessary. Safety is first and foremost. Ease of use is secondary.?
SUVs can do a very good job of pulling a trailer. With most 3HBP SL trailers, you can shift your loads to help balance the trailer and lessen the tongue weight on the towing vehicle. This usually is not available on 2HBP ST trailers.
The longer the wheelbase of the SUV, the more stable it will be. Suburbans, Expeditions and the like have done well towing for many years. The vehicles must be adequately prepared for towing. This would include the largest motor and a proper rear axle ratio. Aux transmission and engine cooling systems are usually included in "towing packages", which should be considered absolutely manditory. Factory installed receivers are the best and are usually part of the packages. Some also include larger brakes, more robust tires and suspension systems, including automatic air height adjustments.
I wouldn't purchase a sway bar system until your rig is on the road and tested. With radial tires installed, most properly loaded trailers track quite well, without needing any auxillary mechanics. Every situation differs and you can't really know yours until you try your first pull.
One of the most important trailer installations components will be an electronic brake controller. Your trailer brakes will be expected to stop their load. Proper brake timing and the strength of the application is paramount. You cannot safetly pull, whilst expecting the towing vehicle to provide all of your braking effort.
A properly prepared SUV can be a good multipurpose vehicle. Just make sure to tick off the options list for the specifics you will need.
MargaretW
Reg. Sep 2010
Posted 2010-09-03 12:45 PM (#124355 - in reply to #124331)
Thanks so much for the info.  I have a 3500 diesel dually quad cab for pulling the big LQ 3h trailer.  I currently have 3 horses however one is pregnant so next year we will have 4.  Don't want to upgrade the trailers so I figure this is the best alternative.  Will be needing to trade in the car soon anyway so ...
I live in Florida near the NW gulf coast.  With hurricane season here in full swing it brings to mind that being able to evacuate all animals is essential.
Will take all of this into consideration when the time comes to go shopping.  Hopefully soon!  Although I do not like the idea of a vehicle payment at all!  I'm not disciplined enough to be able to do it otherwise evidently.
