leveling trailer while hitched up.
Last activity 2010-09-01 11:06 PM
13 replies, 7221 views
arrowfour
Reg. Jan 2010
Posted 2010-08-29 7:36 AM (#124163)
Subject: leveling trailer while hitched up.
goodmorning: I have questions reguarding the distance my trailer "nose" should be from my truck bed sides- to keep from causing damage to the truck... The trailer is a new Elite 23' floor frame. It was 4 inches higher in the front frame to ground measurement than rear so they changed the hitch one more hole to more level the trailer. Now it is so close to truck bed sides it worries me. The trailer has a dropped nose which I love -and but I sure don't want to damage my truck...which is a 2008 Dodge 3/4 ton diesel with air bags. I even let all the air out of the bad to see if it made a difference which was nothing really...Your opinions? Thankyou.
watermarkfarm
Reg. Aug 2010
Posted 2010-08-29 2:44 PM (#124175 - in reply to #124163)
Subject: RE: leveling trailer while hitched up.
I just bought a gooseneck and had the hitch installed took the whole shebang to the trailer repair man for him to make sure I had it all correct. I was told that you want 6" minimum clearance between the nose and the truck bed rails. Mine has more like 9" clearance with the trailer level. I hope that helps.
hogtownboss
Posted 2010-08-29 10:09 PM (#124186 - in reply to #124163)
10001001001002525
Originally written by arrowfour on 2010-08-29 7:36 AM
Well somewhere around 6" is what you are looking for.  The problem is the length of the trailer being a little shorter having the dropped nose.  These set ups work great on flatbed trucks but alittle tight on trucks with regular beds.
My opinion I would raise it back up one hole or another fix is to get the trailer dealer to change out the slide in part of the hitch to the older style that just uses the bolts on the outside to make the adjustments then you can fine tune the adjustment you want.
Or the last thing is to block the axles of the trailer 2".
Edited by hogtownboss 2010-08-29 10:12 PM
wyndancer
Reg. Apr 2007
Posted 2010-08-30 7:39 AM (#124192 - in reply to #124186)
If you really like the truck/trailer combination...the only good fix is to block the axles.
Phoresic
Reg. May 2010
Posted 2010-08-30 7:41 AM (#124193 - in reply to #124163)
500
What is a "dropped nose"?  Thanks.
Nashyboy
Reg. Aug 2009
Posted 2010-08-30 11:18 AM (#124199 - in reply to #124163)
Nashyboy
Reg. Aug 2009
Posted 2010-08-30 11:33 AM (#124201 - in reply to #124163)
Thankyou for your replies. I have a cushion coupler hitch and my axles are blocked 2inches already - from factory new.  I can't hook it up right now to measure exactly but I believe it maybe 6 inches... from eyeballing it...It sure looks close to me from the way it was- (up one hole)-They (factory) like the trailer level as possible for warranty purposes.  My truck wasn't there when they changed it and when we hooked up to go home, no one really paid attention ...we were all in a hurry and it wasn't mentioned... until we got on the road and noticed. I will have to hook up and make sure it is at least 6 in... hope so! I just needed to know what the shortest distant should be at least...Thankyou! It will bear watching that is for sure...! Yup-flat beds would be best.
 A "dropped nose" is to make more room in the nose part in the LQ so we can sit up-just have more head room. Some LQ noses don't have much room when you get a mattress in there- easy to bump head on ceiling...
Nashyboy
Reg. Aug 2009
Posted 2010-08-30 11:37 AM (#124203 - in reply to #124163)
Well, sheesh... looks like I have two names on here...? Couldn't remember password and now I have two names...? I was arrowfour the first time...
Posted 2010-08-30 10:31 PM (#124233 - in reply to #124163)
If all else fails...replace your pickup bed with a flatbed...
http://www.hillsboroindustries.com/Products/AluminumTruckbeds.aspx
wyndancer
Reg. Apr 2007
Posted 2010-08-31 9:02 AM (#124242 - in reply to #124163)
Hey Paul,Any idea (guess)what the ballpark price is for a bed to replace a short bed on a '01 Ford F250?Looks like nice work.
hogtownboss
Posted 2010-08-31 10:16 AM (#124248 - in reply to #124201)
10001001001002525
Originally written by Nashyboy on 2010-08-30 11:33 AM
Is your truck a 2 wheel or 4 wheel drive?  I it is a 2 wheel drive and you are 100% sure you already have 2" blocks you should be level with zero issues!
But on the other hand if you have a 4x4 you will either have to live with it being a little off or replace the 2" blocks with 3" or 4" blocks which is going to have a greater step up in the rear for the horses.  This is the main problem with buying a trailer with a dropped nose, you gain room inside but really can not use a 4xr4 truck unless you have a flatbed or larger block to get it level.
arrowfour
Reg. Jan 2010
Posted 2010-08-31 10:54 PM (#124272 - in reply to #124163)
Thanks for all the input. I hooked up today and measured the closed point is right at 7 inches. I am  understanding that will work...? I will still keep an eye on it if off road for sure... (I have a 2 w.D. long bed.)
hogtownboss
Posted 2010-09-01 10:08 AM (#124283 - in reply to #124272)
10001001001002525
Originally written by arrowfour on 2010-08-31 10:54 PM
Sounds like 7" is plenty.... I hooked up Sundowner last night to a friends Dodge dually 2 wheel drive and it only had around 2" between the bed rail and trailer.  But I also have my hitch rasied all the way up so the trailer is level with my flatbed Dodge.
This is what I would try if the trailer is still to high in the front.  Raise the hitch to the next setting and recheck.  6" is just kind or a rule of thumb, but with in an inch or so you sound be fine.
So my point is if I was to extend the hitch on my trailer to hook up to my friends Dodge, I would have good clearance and the trailer would be level.  My trailer does have the dropped nose.
Posted 2010-09-01 11:06 PM (#124304 - in reply to #124242)
Originally written by wyndancer on 2010-08-31 9:02 AMHey Paul,Any idea (guess)what the ballpark price is for a bed to replace a short bed on a '01 Ford F250?Looks like nice work.
It varies based on shipping and what features you get...LED lights vs bulbs, how many under deck compartments, do you have to have one or two filler slots, and finally what the company charges you to install it and if you have the pickup bed that they have to remove or just a C&C...and finally how long a bed you elect to get...approximately $4500 installed for aluminum with LEDs and multiple under deck compartments should be in the ballpark and that includes a 25000 lb rated hitch and a CLASS V bumper hitch
Edited by PaulChristenson 2010-09-01 11:10 PM
