Aluminum camper door pitting?
Last activity 2010-09-19 5:18 PM
7 replies, 6784 views
ImaSparkyAce
Reg. Jan 2010
Posted 2010-08-26 7:11 AM (#124072)
Subject: Aluminum camper door pitting?
I bought a trailer a few months ago and the camper door is pitting on it. Didn't think this was possible on aluminum. Just wondering if there is any way to stop/fix it or will I have to replace the entire door?
Posted 2010-08-26 8:44 AM (#124079 - in reply to #124072)
Subject: RE: Aluminum camper door pitting?
Look close and see if it isn't pitting from the inside-out....  Those doors are filled with foam, water eventually leaks inside, soaking into the insulation, holding water against the bare aluminum inside the door causing it to "rust" oxidize from the inside out... Couple of fixes, replace skin and seal door to keep inside dry, or, replace with a new door.
http://www.pplmotorhomes.com/parts/rv-locks/rv-entry-doors.htm
evallone
Reg. Jul 2004
Posted 2010-08-28 3:34 PM (#124145 - in reply to #124072)
thx for posting this.  i have the same problem with a four star trailer and I keep it in a shed!  So, will go see what water may be inside the door....
ImaSparkyAce
Reg. Jan 2010
Posted 2010-09-13 6:18 PM (#124834 - in reply to #124145)
It is pitting on the inside....is there any way I could do the fix myself or should I take to the dealer? It may be a bigger project then I am able to take on....
Posted 2010-09-13 9:55 PM (#124845 - in reply to #124072)
If you can access the inside of the panel, you can stop and repair the corrosion. Does the outside of the skin have penetrating holes?
evallone
Reg. Jul 2004
Posted 2010-09-13 9:57 PM (#124846 - in reply to #124845)
Can you explain how to stop and repair, as you suggested?  I believe I can access the inside of my panel.
Posted 2010-09-14 8:36 AM (#124862 - in reply to #124072)
You will need access to the inside of the panel to effect this maintenance. To stop the corrosion, you will have to apply an acid by scrubing the aluminum with a pad. When the acid has stopped reacting, the panel will then have to be generously flooded and rinsed with water. If there is any corrosive pitting, then it will have to be addressed with an epoxy filler.
If you are able to reach the inside panel to effect these actions, let me know and I'll furnish more detailed instructions.
Jbsny
Reg. Apr 2004
Posted 2010-09-19 5:18 PM (#125011 - in reply to #124072)
10010010025
well, I noticed my camper door doing the same thing.. it's a 1999 Featherlite...
I don't think there is any way I can access the panel interior. I'd love to just take off both sides and put a heavier alum on the outside and another panel on the inside... like the inside of the horse door.
Sad that the stuff reacts and the manufacturer didn't come up with a better solution.
Jbsny
