cowboy shower installation
Last activity 2010-08-21 8:55 PM
7 replies, 10528 views
Phoresic
Reg. May 2010
Posted 2010-08-19 1:28 AM (#123757)
Subject: cowboy shower installation
500
I've read in a couple of threads that the cost for having a cowboy shower installed is $2500.  Can someone tell me why it would cost that much?  What is involved that would make it that time consuming and costly to install?
Thanks.
jim bob
Reg. Jan 2008
Posted 2010-08-19 11:55 AM (#123769 - in reply to #123757)
Subject: RE: cowboy shower installation
If you were taking a trailer that had nothing but a dressing room and adding a cowboy shower; you would need the following:  Battery box and battery, holding tank for fresh water, 12 volt Shur Flo pump, lp tanks and plumbing for lp, hot water heater and 12 volt on/off switch, plumbing lines, labor to install all of the above and for cutting the hole in your slant wall to mount the faucets and shower head; and possible a grey water holding tank under the trailer (this would be an option, as most folks with a cowboy shower would drain the water on the ground).  If you don't mind cold showers, you can eliminate the LP system and water heater.
There is a lot more that goes into a cowboy shower than what you might think.
Phoresic
Reg. May 2010
Posted 2010-08-19 12:11 PM (#123770 - in reply to #123757)
500
Thanks for the complete answer.  That does explain a lot of the cost!
watermarkfarm
Reg. Aug 2010
Posted 2010-08-19 3:00 PM (#123779 - in reply to #123757)
Go to the camping supply place and buy a solar shower bag for $20. We lay several out during the day and have enough hot water for 3 showers by evening. Cheapest cowboy shower out there. Just hang up in trailer and shower.
Phoresic
Reg. May 2010
Posted 2010-08-19 3:20 PM (#123785 - in reply to #123757)
500
Thanks for the suggestion.  I was asking more out of interest in the complexity of the system than for my personal use.  I have a Coleman Hotwater on Demand that I will set up so that it can stay in one location and perform all of the functions for which warm water is needed, and most for which cold water is needed.  It should be able to be the shower, sink, pump water to each horse stall and possibly pump water to the outside for a rinse off of the horses.  I should be able to all of that without moving the unit at all.
I do agree that the little solar showers you mention are very effective for a warm shower.  I think they even make water tanks for the hay rack in a dark color so that the water is warm.
Thanks!
jackbrat
Posted 2010-08-19 3:24 PM (#123788 - in reply to #123757)
500100
I have come back from a ride so many times to the Solar shower bag being cold already. I go for long rides and come back in a little later than most. This year it has not gotten that hot all summer long.
Phoresic
Reg. May 2010
Posted 2010-08-19 4:51 PM (#123794 - in reply to #123757)
500
The Coleman Hot Water on Demand works very well.
trot-on
Reg. Dec 2009
Posted 2010-08-21 8:55 PM (#123899 - in reply to #123757)
A friend used the solar shower method, and had a little blow up kids "pool" that they would inflate, then stand in it to catch the water instead of getting the inside of the trailer wet. I've used a much bucket to catch the water. I saw one person who had actually put a hole with a drain in their trailer floor to let the water out. If you want to do the outside method in a swimsuit, so it does not matter if you are seen, I picked up this tiny little plastic pallet at my feed store that is ab ut 18x24", and standing on that, keeps my feet off the ground, and out of the mud puddle.
