Ceramic Roof Coating
Jump to page : 1 2
Last activity 2010-09-03 9:09 AM
29 replies, 12298 views
crowleysridgegirl
Reg. Apr 2005
Posted 2010-08-29 2:53 PM (#124176 - in reply to #124147)
Subject: RE: Ceramic Roof Coating
2000500100
I for one wanted a general estimate because I don't really want to expend my time or someone else's (the businessman) if I know pretty quickly whether I can spring for the cost,or not.
Thanks for your post.
Posted 2010-08-29 4:48 PM (#124178 - in reply to #123740)
Not too long ago, there was another thread about ceramic roof products. Bartley Heath has done some research on roof temperatures and found the following: Bare aluminum skin has the same reflectivity as black. With an outside temperature of 90 deg F, the skin temp was about double the ambient temperature. By applying a white paint, these temperatures dropped ~50 deg F.
I've painted a few trailers' roofs, steel and aluminum, with marine paints. Like Bartley, I have found the inside temps easily dropped ~15 deg F. These paints can be the basis for a DIY project at a fraction of the quoted ceramic costs. According to one pleased ceramic owner, you can realize the same inside temperature reduction with paint and a roller.
crowleysridgegirl
Reg. Apr 2005
Posted 2010-08-30 5:43 PM (#124217 - in reply to #124178)
2000500100
What would be the proper preparation to paint an aluminum roof with white marine paint? (one time.)
Jbsny
Reg. Apr 2004
Posted 2010-08-30 6:28 PM (#124220 - in reply to #123740)
10010010025
http://www.hytechceramics.com/buy.html
I wonder if I could roll this stuff on with a brush...
Jbsny
Posted 2010-09-03 9:09 AM (#124341 - in reply to #124217)
Originally written by crowleysridgegirl on 2010-08-30 6:43 PM
To coat a roof, it should be first washed and cleaned of all contaminates. Then depending on the paint's manufacturer, an approved primer is applied. The paint I use is a single part polyurethane, that can be sprayed, rolled or brushed on. It has a good flow rate that results in a smooth, high gloss finish. On a hot day, to prevent the paint from flashing too quickly, a reducer should be added to the paint, to prevent it from drying too soon.
Jump to page : 1 2
