Need Exiss replacement drop down window
Last activity 2010-08-17 4:01 PM
9 replies, 17005 views
nbr
Reg. Apr 2009
Posted 2010-08-16 5:26 PM (#123622)
Subject: Need Exiss replacement drop down window
Gurr, lost a tire and it took out my fender and one of the windows in my drop downs.  Where is the best place to get a replacment window? Do I have to get the whole drop down window part or can I hopefully get just the window part? 02 Exiss LQ ,I beleive it is a Hehr window. On Hehr's website it shows the whole drop down assembly.
Thanks
laurie
Reg. Jun 2004
Posted 2010-08-16 6:51 PM (#123624 - in reply to #123622)
Subject: RE: Need Exiss replacement drop down window
10010010010025
watch the side of the road. Seems they fall off periodiacally :)
My sisters is in OK somewhere
flyinghfarm
Posted 2010-08-16 7:19 PM (#123626 - in reply to #123622)
1000100100
is it glass only that was damaged?  (not sure if hehr, tire, or fender is lying on the road or ?!! ) Most likely glass, or window, can be replaced after your tire took out the FENDER and WINDOW!  Will check some for you..
AND here it may be!
http://www.hehr-international.com/200horsetrailerhome.htm
Edited by flyinghfarm 2010-08-16 7:22 PM
nbr
Reg. Apr 2009
Posted 2010-08-16 8:54 PM (#123627 - in reply to #123622)
the glass in the window is shattered.The outside frame of the complete drop down is bent, but I can straighten it. The fender, well I will be replacing it in the next few weeks. Right now I am just concerned with getting the window repaired. Spoke with the nearest Exiss dealer (3+hours away) Window maybe avaliable need to pull the other one out to get them the part number. I am going to try a local glass shop and see if they can just replace the glass for me???
flyinghfarm
Posted 2010-08-16 10:05 PM (#123630 - in reply to #123622)
1000100100
A lot of times they can make a custom piece of glass for the window.....it needs to be safety glass and tinted to match your other windows if they are tinted, and they can provide all of this, most likely..
blackcows
Posted 2010-08-17 9:03 AM (#123638 - in reply to #123622)
100100100100252525
This one had been on eBay for months....not sure if it's a good deal or not.
http://cgi.ebay.com/ebaymotors/Exiss-Drop-Down-Door-Window-Very-Rare-_W0QQcmdZViewItemQQitemZ170447723766QQptZLHQ5fDefaultDomainQ5f100
Mike
lesliemal
Reg. Sep 2007
Posted 2010-08-17 9:04 AM (#123639 - in reply to #123622)
JMHO if the frame is bent, maybe you should just replace the whole drop down. You might have trouble getting it to close properly. I had the same thing happen and it was a mess. I replaced the whole drop down window. If you had your drop down attached to a manger door, you need to check that too. It bent the frame on my manger door and sprung the locking mechanism. I was able to salvage the manger door, but had to replace the lock. Luckily, my trailer was less than 2 years old so my manufacturer sent me all the parts I needed for free. The tire manufacturer paid me market value for all 5 of the tires that came on the trailer new after much "discussion". So sorry that it happened to you too. Good luck in getting everything fixed.
nbr
Reg. Apr 2009
Posted 2010-08-17 3:41 PM (#123664 - in reply to #123639)
My trailer does not have mangers, so alteast I don't have to worry about the manger door! (one positive) Just the silver part of the drop down window frame is bent in one area I am pretty sure we can get it straightened out.  HATE to pay $200+ for awhole new dropdown window when I am looking at spending $800 for new tires. My tires are less than 2 years old, but sure don't want to take any chances. You were lucky to have the copmany help you out.
Posted 2010-08-17 3:52 PM (#123665 - in reply to #123622)
When you go to the glass shop, also ask about the possibility of installing a 1/4" thick piece of Lexan. It is lighter than glass, almost indestructable and scratch resistant. It's also faster to cut and work than safety glass, and many shops would have a scrap piece that size left over from larger projects.
nbr
Reg. Apr 2009
Posted 2010-08-17 4:01 PM (#123666 - in reply to #123665)
ok, I am headed to the glass shop in just a bit. Will be sure to ask about the Lexan.
Thank you
