Trailer stabilization
Last activity 2010-07-14 11:15 AM
11 replies, 7096 views
genebob
Reg. Nov 2007
Posted 2010-07-14 9:52 AM (#122358)
Subject: Trailer stabilization
Our previous trailer had two jacks and was very stable when unhooked. The new (to us) trailer only has one jack and we noticed whike on vacation that you can feel and hear the a little bit of sway side to side when moving around in the trailer. My question is, has anybody ever used trailer jacks-stabilizers like RV's use? I was thinking maybe putting them under the bumper to reduce the sway.
Tresvolte
Reg. Feb 2008
Posted 2010-07-14 9:57 AM (#122359 - in reply to #122358)
Subject: RE: Trailer stabilization
I've got a set of jack stands that I carry in my mangers that I use under the front end of the trailer. They work great for a lot less money.
RAF
Reg. Jan 2009
Posted 2010-07-14 9:58 AM (#122360 - in reply to #122358)
stab jacks will help but put them under the front if you install them at the rear you will ripe them off . good luck and have fun
Phoresic
Reg. May 2010
Posted 2010-07-14 10:16 AM (#122362 - in reply to #122358)
500
I don't know if this will help but here goes.
Edited by Phoresic 2010-07-14 10:18 AM
genebob
Reg. Nov 2007
Posted 2010-07-14 10:28 AM (#122363 - in reply to #122358)
I planned on using the portable kind like Tresvolte. But why the front? It seems that the sway comes from the axles.
Tresvolte
Reg. Feb 2008
Posted 2010-07-14 10:35 AM (#122364 - in reply to #122358)
Because the single jack is what is letting the trailer pivot. You will get a small amount out of the axles, but not near what you get from the front. Try it both ways and see which you like better...
Posted 2010-07-14 10:39 AM (#122365 - in reply to #122358)
Would a pair of these work? Trailer weight remains on the jack, these just help prevent that ying yang, side to side sway....
http://www.pplmotorhomes.com/parts/rv-jacks/stabilizer-jack-rv.htm
Or if you're as lazy as I have become in this heat....
http://www.pplmotorhomes.com/parts/rv-jacks/rv-electric-stabilizer-jack.htm
Edited by retento 2010-07-14 10:40 AM
genebob
Reg. Nov 2007
Posted 2010-07-14 10:40 AM (#122366 - in reply to #122358)
Thanks! This is wht's great about this forum, ask a question and you knowledgable answers.
genebob
Reg. Nov 2007
Posted 2010-07-14 10:43 AM (#122367 - in reply to #122358)
Retento- They probably would, but it looks like the top bar is one piece, and I have my gas line running there I think. Better go look.
Tresvolte
Reg. Feb 2008
Posted 2010-07-14 10:44 AM (#122368 - in reply to #122365)
Originally written by retento on 2010-07-14 10:39 AM
I like those, but I am cheap so I use these... http://www.northerntool.com/shop/tools/product_200305225_200305225
genebob
Reg. Nov 2007
Posted 2010-07-14 10:57 AM (#122369 - in reply to #122358)
I am cheap too! The car jacks might work. Just looked, the gas line goes to the front frame cross member, turns 90 and goes under it to about 3" from outside wall then 90 turn to the back. If I carefully put the jacks in, they would work. I think my FIL has some old screw up ones from his old camper sitting around yet. Maybe I'll go look for them. Cheaper yet. FREE!
Tresvolte
Reg. Feb 2008
Posted 2010-07-14 11:15 AM (#122371 - in reply to #122358)
Free is as good as it gets!!!
