Tire Protection ...summer & winter
Last activity 2010-07-13 2:54 PM
1 replies, 3118 views
To Much Trouble
Reg. Dec 2009
Posted 2010-07-13 1:10 PM (#122310)
Subject: Tire Protection ...summer & winter
After dealing with a dry rot issue on fairly new tires last fall...what do you do to protect your tires on your horse trailers.. The trailer was purchased from the east coast..and was not stored inside ( hence the dry rot problem) Here ( midwest) it is stored inside when not in use... and in the winter..is there anything a person should do to help the life expectancy of the tires on trailers.. either stored inside or out ?  THANKS
Posted 2010-07-13 2:54 PM (#122320 - in reply to #122310)
Subject: RE: Tire Protection ...summer & winter
Keep them inside and covered if possible. Keep them off the ground, concrete or steel plates work fine. No armoral, or tire gloss products.... Most contain alcohol which pulls the natural oils out of the tire, hence they dry rot and crack. And one thing that helps probably more than anything, just like you and I, the tires need exercise, they need to be uses, rolled at highway speeds, so they can flex and remain pliable and flexable. You won't see many tires that roll a little every day that rot and crack. It the ones that sit around and do nothing that go bad.... Just like people.....!!
Edited by retento 2010-07-13 2:57 PM
