No Power, even when plugged in??
Last activity 2010-07-11 2:14 PM
2 replies, 3745 views
PRETTY PONY
Posted 2010-07-10 11:03 PM (#122185)
Subject: No Power, even when plugged in??
Can someone tell me where to start troubleshooting? My living qtrs is plugged in but I still have zero power inside, no lights, no nothing. I have checked the breakers, have a fairly new converter. Is there an line fuse for the converter I need to check next? I have always had battery issues so I try to keep the trailer plugged in most of the time when I am not using it. I can't even run my generator.
brushycreekranch
Reg. Jun 2006
Posted 2010-07-11 7:37 AM (#122193 - in reply to #122185)
Subject: RE: No Power, even when plugged in??
500100100100100
Most conversion companies also put a fuse up in the battery box under the gooseneck. Something else to check is to make sure the battery on/off lever hasn't bumped out of position.
Posted 2010-07-11 2:14 PM (#122208 - in reply to #122185)
Contact your trailer/LQ mfg. They should be able to run you through a trouble shooting sequence enabling you to find any trouble areas. Hidden fuses, relays, switches, etc....
