and found out it didn't get very cold and I got sort of sick even th the windows open. So, switched to electric when I got home and the coldest I could get the freezer was icewater not ice. Looked all over cannot find a gas leak. Tried the gas again -- cannot keep it lit on gas anymore. Won't ignite. ');">Its a 2000 trailer with a professionally done living quarters and the use is light (maybe 6X per year), and shed kept. Could find no mudwasps or other clogs anywhere. Any ideas how I can troubleshoot or what may be wrong here? Just really don't want to take it to a shop til I tried it all myself - don't need the bill or the runaround I typically get there. Its a Dometic midsized fridge. Just a 4' shortwall trailer."/>
Living Qtrs Refrigerator Problem - Help Request
Last activity 2010-07-16 7:11 AM
12 replies, 7407 views
evallone
Reg. Jul 2004
Posted 2010-07-10 1:42 PM (#122161)
Subject: Living Qtrs Refrigerator Problem - Help Request
OK I have a living quarters with a gas/electric fridge.  Fired it up and smelled gas.  Stubbornly persisted to use it anyway 2 and found out it didn't get very cold and I got sort of sick even
th the windows open.  So, switched to electric when I got home and the coldest I could get the freezer was icewater not ice.  Looked all over cannot find a gas leak.  Tried the gas again -- cannot keep it lit on gas anymore.  Won't ignite.  16
Posted 2010-07-10 2:34 PM (#122164 - in reply to #122161)
Subject: RE: Living Qtrs Refrigerator Problem - Help Request
Did you smell ammonia or gas? If you are running the fridge on electric, you should be able to feel heat from the electric heater above where the gas flame ignites. It takes several minutes to reach the proper temp. If this is warm, and the fridge doesn't cool with either the gas or electric, you probably have a cooling system problem.
The electric takes longer to cool than the gas. If the fridge eventually cools down, the cooling system is ok. If the gas isn't working, the first thing to check is the supply, and then the burner orifice. The supply can be checked by running the burners on a cook top. A good flame indicates a good regulator and sufficient tank supply. The burner orifice can be removed and cleaned, do not enlarge the hole.
If this fails to provide an adequate flame, then there are a few other components in the gas burner area that could be causing a problem; a thermostat, safety valve or thermocouple. I would recommend  their replacement be accomplished by a skilled mechanic.
Many gas fridges can have if necessary, their cooling systems rebuilt or repaired.
evallone
Reg. Jul 2004
Posted 2010-07-10 2:40 PM (#122166 - in reply to #122161)
Hey thanks for your generous advice.  I thought I smelled propane, but not sure what the ammonia smells like perhaps I got that wrong.  All other propane (cooktop, gas water heater) work just fine.  I left the fridge on electric/high  overnight and only got it cool enough to chill water in the freezer.  On gas, it will no longer ignite.  It was igniting, then quitting, but now it won't do that either.
laurie
Reg. Jun 2004
Posted 2010-07-10 5:46 PM (#122177 - in reply to #122161)
10010010010025
Personally if I thought I smelled gas and felt sick I would go get the run around from my dealer Vs carbon monoxide poisoning while I am sleeping. But I prefer to live another day.
mingiz
Reg. Jul 2004
Posted 2010-07-10 8:02 PM (#122179 - in reply to #122161)
I basically had the same problem last year with mine.In the long run it was cheaper to replace it. If your mechanically incline you can replace it your self. It was 7yrs old when i replaced it.
evallone
Reg. Jul 2004
Posted 2010-07-10 10:47 PM (#122184 - in reply to #122161)
Well, that gives me the idea its not unusual for them not to last all that long.  Much appreciated.  It may be best for me to go out ad get an ICE BOX they sure never go bad  18And, they cost a whole lot less to buy.  I'll have to think it all over..  Thanks again.
Mira
Reg. Feb 2009
Posted 2010-07-13 8:29 AM (#122281 - in reply to #122161)
Hi we just replaced the Dometic fridge yesterday in our living quarters it ran 24 hours a day for the last eight years so I figure we got good use out of it !I smelled ammonia really bad before it went did two, week long trips, without the fridge hated it had to have my fridgeI did buy one of those electric/cigarette lighter coolers from walmart to keep a few things cold didn't hold much but does keep things cold I hate fooling with ice especially if you have to drive to find it!Mira
evallone
Reg. Jul 2004
Posted 2010-07-13 3:33 PM (#122326 - in reply to #122161)
These have been VERY helpful posts. Thanks.  Its possible I am guessing that age matters more than use - i.e. the fridge has a number of years its going to work whether you use it or you don't.  Well, that said, I am with you about the not wanting to find ice...
Can't say how much I appreciate having a place where people will send advice to me.
 I sure do need it.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-07-13 8:26 PM (#122341 - in reply to #122161)
Just for the giggles I would question your Propane detector.
If you smelled Propane and got sick (Which is great you woke up to see the next day) it should have gone off.
Edited by BlazingCreekBar 2010-07-13 8:27 PM
evallone
Reg. Jul 2004
Posted 2010-07-13 8:58 PM (#122345 - in reply to #122161)
I thought about that too.  I imagine I was smelling ammonia.
dawnb
Posted 2010-07-14 3:00 PM (#122378 - in reply to #122345)
Why not call the conversion company and see if they can shed any light on the subject? They might be able to help you and they might even have an 800 phone #.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-07-15 7:54 PM (#122432 - in reply to #122161)
There were recalls on dometic fridges blowing amonia and burning the rig to the ground.  Make sure you ask if this damage is covered under that recall.  See the dometic site for your model.
evallone
Reg. Jul 2004
Posted 2010-07-16 7:11 AM (#122441 - in reply to #122161)
I will get right on that!  Thanks so much.  Eleanor
