Slight mildew odor
Last activity 2010-07-31 2:03 PM
2 replies, 3636 views
Sheryl
Posted 2010-07-05 2:17 PM (#121918)
Subject: Slight mildew odor
I have noticed a mildew odor in my shower the first time I use it on trips.  It usually goes away after my first shower. It has a "SHUB" shower door.  It retracts into a holder.  Says it is mold & mildew free.  Has anyone else had this problem and what did you do to eliminate it?
I don't believe it is coming from the grey tank as I cover the shower drain with a flat stopper while not in use.
Edited by Sheryl 2010-07-05 2:18 PM
BlazingCreekBar
Reg. Nov 2008
Posted 2010-07-06 5:55 PM (#121969 - in reply to #121918)
Subject: RE: Slight mildew odor
So I learned something new this season.
I learned that all the little plastic knobs for the water connections loosen up over time.
Especially the water lines going up to my shower handle.  Must be the road sway.
I had to take an access pannel off inside a closet and found each knob was almost a full turn to make tight.
Just an idea you might look into.
Sheryl
Posted 2010-07-31 2:03 PM (#123038 - in reply to #121918)
After two more camping trips, I have determined that the odor was coming from the shower head (or the water lines).  I'm re-bleaching my whole water system and I'm sure this will take care of it.
