How much bedrail clearance in enough???
Last activity 2010-06-24 9:37 AM
4 replies, 4522 views
brendaclemens
Reg. Jan 2009
Posted 2010-06-15 9:31 PM (#121188)
Subject: How much bedrail clearance in enough???
Bought the new truck 4x4 Dodge 3500, expected to have the problem, but do not know how much clearance I need. It is scary watching that nose get close to the new bedrails! Right now it has 6", I can have my axles blocked...but what I need to know is what to ask for. Help is appreciated :) My trailer is an Elite and has a drop nose.
Posted 2010-06-15 10:57 PM (#121190 - in reply to #121188)
Subject: RE: How much bedrail clearance in enough???
For the type of roads that I drive, 6" is not enough. I have raised teh gooseneck coupler to lift mine up to 9".
Try raising your coupler first before you go to the trouble of blocking your axles.
brendaclemens
Reg. Jan 2009
Posted 2010-06-15 11:20 PM (#121192 - in reply to #121188)
Thank you for the reply. I would feel good about 9 inches of clearance. If I raised the coupler, the trailer is too slanted :( I don't mind blocking, but then I think I will need a ramp as it would put my rear bumper at 23"...and the list goes on eh?
brushycreekranch
Reg. Jun 2006
Posted 2010-06-16 7:53 AM (#121196 - in reply to #121188)
500100100100100
We put a cody air ride hitch in our 2010 dodge. Also used it in the 08 Ford. It raises the ball higher without having  to mess with the coupler. Since I use two different trucks to pull the same trailers, I can make adjustments by just adding or letting air out of the hitch.
brendaclemens
Reg. Jan 2009
Posted 2010-06-24 9:37 AM (#121488 - in reply to #121190)
Painted Horse...THANK YOU! I would have never thought 9"...raised it to 9" before my trip to Devils's Den, if I would have been 8 1/2" my new truck would have had a big boo boo!
