Furnace - easy fix?
Last activity 2010-06-13 10:25 AM
8 replies, 4232 views
Slidinspots
Posted 2010-06-11 10:17 PM (#121073)
Subject: Furnace - easy fix?
My heat was working great the last time I used it in April. This weekend it would only blow cold air. Is there something simple I can check before taking it in to be fixed?
brushycreekranch
Reg. Jun 2006
Posted 2010-06-12 7:50 AM (#121078 - in reply to #121073)
Subject: RE: Furnace - easy fix?
500100100100100
Are you sure you have propane and the tanks are turned on? My furnance blows cold air when out of propane.
Slidinspots
Posted 2010-06-12 5:32 PM (#121089 - in reply to #121078)
Yes and I tried both propane tanks thinking one may have been low and not enough pressure even though both registered "green". I lit the stove, which is above the heater so I know propane was getting that far.
Jeepplr
Reg. Oct 2007
Posted 2010-06-12 9:16 PM (#121099 - in reply to #121073)
If I have turned the propane off it can take a long time for propane get to my furnace.
Are you able to light the stove or is there just air coming out that got into the line?
mingiz
Reg. Jul 2004
Posted 2010-06-13 8:17 AM (#121107 - in reply to #121073)
Have you check the pilot on the furnace to make sure it isn't stopped up with dirt etc.
BigT
Posted 2010-06-13 9:39 AM (#121109 - in reply to #121073)
I don't know if your furnace has one, but when my heater woiuld not throw hot air, I replaced the thermocouple.
Edited by BigT 2010-06-13 9:41 AM
Slidinspots
Posted 2010-06-13 9:56 AM (#121110 - in reply to #121099)
Yes I was able to light the stove.
Slidinspots
Posted 2010-06-13 9:57 AM (#121111 - in reply to #121107)
OK I will open it up and look. I didn't want to open anything up if there wasn't anything I could do. Thanks.
brushycreekranch
Reg. Jun 2006
Posted 2010-06-13 10:25 AM (#121112 - in reply to #121073)
500100100100100
Do you have a "dirt dobber" screen cover on it?  If they have gotten in, it can plug it enough that it won't work.
