Help with replacing or repairing roof
Last activity 2010-06-01 8:25 AM
2 replies, 4583 views
Daisy Mae
Reg. Jun 2010
Posted 2010-06-01 7:36 AM (#120781)
Subject: Help with replacing or repairing roof
Good Morning All,
After lurking for quite some time, I finally registered.  I need help with my roof problem.  I have a fiberglass roof and need to replace or repair it. I have heard of a rubber type roof but am unfamiliar with it.  Can you please give me your suggestions on replacing or reparing it?  Thank you for the help.
Posted 2010-06-01 8:19 AM (#120783 - in reply to #120781)
Subject: RE: Help with replacing or repairing roof
Without a detailed examination, it would be impossible to determine a cause of action. Changing an entire roof would be expensive. Fiberglass is relatively easy to repair, especially considering the mostly flat areas. Installing a rubber membrane or elastomeric coating, would necessitate having a substantial, supporting roof underneath.
Daisy Mae
Reg. Jun 2010
Posted 2010-06-01 8:25 AM (#120784 - in reply to #120781)
Thanks Gard,
It seems that the roof has buckled and seperated at the seam nad has caused the roof to leak into my living quarters.  I have been told that the best way to go is with the rubber type roof b ut since I am just investigating this issue, I am unfamiliar with the terminology. Thanks again.
