How do you drain the fresh water tank?
Last activity 2010-05-20 10:38 PM
9 replies, 14149 views
summit_bound
Reg. Apr 2010
Posted 2010-05-18 8:13 PM (#120329)
Subject: How do you drain the fresh water tank?
I must be dense or something. I can't find a valve or outlet anywhere on my trailer to drain the fresh water tank. Which obvious thing am I missing?
Posted 2010-05-18 9:09 PM (#120331 - in reply to #120329)
Subject: RE: How do you drain the fresh water tank?
The water exits the tank from the bottom area. Many times the supply line will have a "tee", going to a drain close to the tank's exit. The drain will be in the supply line at some point, and should be at the water line's lowest point within the LQ.
summit_bound
Reg. Apr 2010
Posted 2010-05-18 11:15 PM (#120339 - in reply to #120331)
Thank you. I will look again tomorrow in daylight.
HERB
Reg. Jan 2010
Posted 2010-05-19 3:00 PM (#120360 - in reply to #120329)
My trailer is a 2008 Lakota /w 12' lq.  I have 2 fresh water tank and they did not put a drain on either one.  There is a line drain near the hot water heater but when sanitizing the tanks I have to run 123 gal. through the pump.  A slight pain but otherwise a happy customer.
captclank
Posted 2010-05-19 3:08 PM (#120361 - in reply to #120329)
My old LQs drainvalve was outside, under the trailer. On the new LQ, the valve in under the couch next to the tank.
summit_bound
Reg. Apr 2010
Posted 2010-05-19 3:11 PM (#120362 - in reply to #120361)
Okay so if the valve is under the couch, how do you drain it? I hope this doesn't sound too stupid. It's my first LQ and I am coming up a steep learning curve! My trailer is an '06 so the drain is probably inside also, I'm guessing.
captclank
Posted 2010-05-19 4:13 PM (#120365 - in reply to #120329)
lift up the couch front and open it halfway...so it is kinda like a "V" instead of fully open, get flashlight and put your head under the couch and see if you can locate it. Good luck.
Posted 2010-05-19 8:17 PM (#120371 - in reply to #120329)
Might it just be easier to look under the trailer for the drain hole?
Gone
Posted 2010-05-20 4:02 AM (#120374 - in reply to #120329)
10002525
Mine is an 06 and it's outside next to the black water drain. They both have handles to pull. The same set up was on my motorhome as well.
summit_bound
Reg. Apr 2010
Posted 2010-05-20 10:38 PM (#120408 - in reply to #120329)
Yup - got under the trailer, saw where the drain pipes emerged, found the line inside with the valve, opened it up and voƮla! Thanks for all the helpful suggestions.
