Should we use max tire pressure
Last activity 2010-05-19 9:50 AM
3 replies, 4398 views
11Snowbird
Reg. Apr 2010
Posted 2010-05-18 7:23 PM (#120325)
Subject: Should we use max tire pressure
We have a 4 horse goose neck 14000lb loaded with 235/85/R16 g tires with a max pressure of 110 PSI Should we run them at max pressure
Posted 2010-05-18 8:07 PM (#120328 - in reply to #120325)
Subject: RE: Should we use max tire pressure
That's what I run in my Goodyear G614RST's. They're rated at 3750@110
http://www.goodyear.com/rv/products/g614rst.html
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
statzk
Reg. May 2006
Posted 2010-05-19 9:45 AM (#120348 - in reply to #120325)
I run the max PSI on my trailer tires. I also run the max of 80 PSI on my truck tires- some will tell you that at the max PSI they will wear faster in the middle, been doing this for years on two different trucks and never had a problem with tire wear (my last set of Michelin LTX lasted 75K miles and still had 25% tread left).
Posted 2010-05-19 9:50 AM (#120349 - in reply to #120348)
Originally written by statzk on 2010-05-19 10:45 AM
I run the max PSI on my trailer tires. I also run the max of 80 PSI on my truck tires, been doing this for years and never had a problem with tire wear .
DITTO
