My first crisis, can I fix this?
Last activity 2010-05-20 11:31 AM
5 replies, 4929 views
blackcows
Posted 2010-05-16 7:33 PM (#120242)
Subject: My first crisis, can I fix this?
100100100100252525
I had a hanger break that held the valve for my grey tank and it drug on the ground and broke.  Since the tank doesn't have any pressure I would think I could fix it but I am not exactly sure how I would do this.  I have attached pictures, any suggestions would be appreciated.
hogtownboss
Posted 2010-05-17 9:52 AM (#120268 - in reply to #120242)
Subject: RE: My first crisis, can I fix this?
10001001001002525
Well this looks like the same thing that happened the Sooner we had a few years ago.  We tried a couple of things to patch it up and nothing worked with the virbration.  Ended up buying a new tank.  Most RV repair shops can order them if they do not keep them in stock.  If you can do the work yourself, ebay also carrys tanks like this, just make sure you get the correct measurments.
blackcows
Posted 2010-05-17 9:57 AM (#120269 - in reply to #120268)
100100100100252525
Thanks for the reply.  I do think a replacement may be the best and probably not that difficult to do.  If I drop the tank what should I expect to find.  I would assume that the sink and the shower would both drain to the tank....how would they connect to the tank?  Any other suprises I should expect or should it be fairly straight forward?
dman
Reg. Apr 2005
Posted 2010-05-17 11:32 AM (#120274 - in reply to #120242)
dman
Reg. Apr 2005
Posted 2010-05-17 11:35 AM (#120275 - in reply to #120242)
there should be a glued in fitting in the top of the tank.  you should be able to disconnect above floor in the lav or sink base.  if not you will need to cut the pipe, above floor, and replace with a coupler on reinstallation.
RWR
Reg. Nov 2009
Posted 2010-05-20 11:31 AM (#120386 - in reply to #120242)
replace the tank.
Also those fittings are glued and you are not going to un-glue them.
Take all your mounting hardware off from the rim around the tank get a pry bar and break to off.
Only way to do it.
It's not hard, just take your time, and think about what you are doing. And always remember,,,,,,,Measure twice, cut once.
