Retento
Last activity 2010-05-14 6:13 PM
7 replies, 4317 views
Gone
Posted 2010-05-14 8:17 AM (#120128)
Subject: Retento
10002525
I now have a vibration in the front end at low speeds and higher speeds. Are you familiar with this? I'm afraid to drive it. This truck has been a pain in my arse.
Edited by Gone 2010-05-14 8:18 AM
Posted 2010-05-14 9:19 AM (#120131 - in reply to #120128)
Subject: RE: Retento
3500 SRW right? Did it start all of a sudden? Driven in the mud before this started? Try rotating tires and see if the shaking moves. Could have slung a wheel weight off. Ball joint, tie rod end may be worn? These trucks also have sealed front wheel bearings. I've heard folks say they've had trouble with them. Starts to vibrate then it begins to get noisy, whines, squeals, roars, etc.. There's no real fix other than replacing the bearings. I got about 90000 on mine and have never had any trouble. It's hard to say what may be wrong without driving it and looking at it on a rack. Take it to a reliable front end shop.... One that likes to work on GM front ends.
hogtownboss
Posted 2010-05-14 10:03 AM (#120138 - in reply to #120128)
10001001001002525
I'm not retento, but I am going to add something else to check as well.  Just happened to a 2001 3/4 ton 4x4 I bought.  Truck run and drove prefect then on the way back to work I got a bad shake at low and high speeds, around 40 or so it would smooth out.
Belt seperated in the tire.  When I looked at the tread there was a high spot going the same direction as the tread about a foot long.
Not meaning to high jack, just another thought.
HTB
Gone
Posted 2010-05-14 10:11 AM (#120142 - in reply to #120128)
10002525
The steering has started to squeal. It started as an occasional vibrate and has gotton to where it happens every time it is driven. Hubby is going to look at after work. I'll let him know of the suggestions of what it may be.....
Edited by Gone 2010-05-14 10:13 AM
genebob
Reg. Nov 2007
Posted 2010-05-14 11:25 AM (#120148 - in reply to #120128)
I will second HTB. Check the tires. Just had the same thing happen on one of our school vans. All we run is Goodyears. They gave us good credit on the new one.
statzk
Reg. May 2006
Posted 2010-05-14 1:34 PM (#120154 - in reply to #120128)
Had the same thing happen on my '09 Jeep (with GoodYear tires). Tread separated and was causing a vibration. As the Jeep only had about 10K mile on it I took it to the dealership and they replaced tire no questions asked, but was kind of alarmed after they showed me the tire after taking it off. My wife and kid use that Jeep 90% of the time, and where we live the speed limits are 55 and 70!
Posted 2010-05-14 3:21 PM (#120160 - in reply to #120128)
Good point on the possibility of a "square" tire... Didn't mention them, figured they had already checked the tires...
Gone
Posted 2010-05-14 6:13 PM (#120168 - in reply to #120128)
10002525
There's play in the tire....bearings maybe?
