How do you hang stuff on the soft walls in the living quarters?
Last activity 2010-06-23 6:49 PM
11 replies, 8333 views
summit_bound
Reg. Apr 2010
Posted 2010-05-05 9:45 PM (#119778)
Subject: How do you hang stuff on the soft walls in the living quarters?
I had this brilliant idea that Command Strips would work but either I put them on wrong, or they don't really stick very well to that surface. I want to hang a lightweight mirror and a couple of hooks in the bathroom and I don't want to drill holes or permanently damage the walls. Any ideas?
cowpony01
Reg. Mar 2006
Posted 2010-05-06 11:59 AM (#119812 - in reply to #119778)
Subject: RE: How do you hang stuff on the soft walls in the living quarters?
100100100100252525
In our 5th Wheel camp trailer, I used two way velcro. Comes in a box, hook side and sticky side. Nothing has fallen down yet. In fact was hard to get a picture off the wall with it to update the picture. It's the 3M brand and I found it at our local Rite Aide. I'm sure any local store similiar to that or Wally World or any hardware place would have some.
summit_bound
Reg. Apr 2010
Posted 2010-05-07 8:16 AM (#119836 - in reply to #119778)
Thanks for your tip. I will give Velcro a try.
blackcows
Posted 2010-06-21 9:36 AM (#121346 - in reply to #119836)
100100100100252525
Originally written by summit_bound on 2010-05-07 8:16 AM
Did the velcro work for you?  I also tried the command strips and they didn't work.
Mike
summit_bound
Reg. Apr 2010
Posted 2010-06-21 9:44 AM (#121347 - in reply to #121346)
The Velcro didn't work either. I think I'll call Outlaw and see if they have any recommendations.
Sheryl
Posted 2010-06-21 11:07 AM (#121350 - in reply to #119778)
The command strips with hooks have worked well for me.  They do have a 3# limit.
summit_bound
Reg. Apr 2010
Posted 2010-06-21 3:33 PM (#121366 - in reply to #119778)
Just talked to the guys at Outlaw about this. They said there's really no adhesive that will really work with the soft walls - you need to use a screw if you want to hang something.
cowpony01
Reg. Mar 2006
Posted 2010-06-21 8:23 PM (#121374 - in reply to #119778)
100100100100252525
The velcro strips did not work? I'm shocked as it's the same interior siding I believe as they use in 5th wheel campers. It worked in ours and in my horse trailer......
hansenshorses
Reg. Dec 2005
Posted 2010-06-23 10:12 AM (#121448 - in reply to #119778)
Get the roll of 1 inch sticky side velcro and that has to work.  Put it on 4 sides of your picture or whatever and hold it on there for a minute. I can't believe that won't stick to the soft walls.
summit_bound
Reg. Apr 2010
Posted 2010-06-23 10:14 AM (#121449 - in reply to #121448)
I'll try it again. Maybe I wasn't using enough for the item I was trying to hang.Once you get it to stick, can you get it off without ruining your wall?
cowpony01
Reg. Mar 2006
Posted 2010-06-23 5:02 PM (#121471 - in reply to #121448)
100100100100252525
That's the same stuff I told her to use. It's sticky on one side to attatch to the wall and the oppostie side is sticky to stick to the picture, mirror, etc. and you then stick the velcro together. I can't believe it won't work either....
It's made by 3M...
Edited by cowpony01 2010-06-23 5:03 PM
CTR Rider
Posted 2010-06-23 6:49 PM (#121472 - in reply to #119778)
I can't get anything to stick on the soft walls either.  It holds for a while, but with the temperature fluctuations, it always turns loose.
