What tire pressure to use when pulling a gooseneck
Last activity 2010-05-04 9:06 PM
4 replies, 6909 views
11Snowbird
Reg. Apr 2010
Posted 2010-05-02 11:44 PM (#119634)
Subject: What tire pressure to use when pulling a gooseneck
What tire pressure should I use on our 99 f350 dually while pulling our goose neck with 3000 llb on the bed, I have been using 80 psi max?
rockyrider
Reg. Jun 2004
Posted 2010-05-03 5:00 AM (#119636 - in reply to #119634)
Subject: RE: What tire pressure to use when pulling a gooseneck
100100100
80 psig sounds right for the rears, I'd go about 65 psig in the front
Posted 2010-05-03 8:12 AM (#119638 - in reply to #119634)
Everyone has his own idea of what is the best inflation:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=12806
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=12287
statzk
Reg. May 2006
Posted 2010-05-04 11:45 AM (#119706 - in reply to #119634)
Don't know about a dually, but on my last truck I got 75,000 miles on my tires and they still had 20%+ tread left, nice even wear and I always had them all four aired up to 80 PSI. Doing the same on my new truck. Has 1700 miles on it in two weeks and 100% of that has been pulling the trailer.We have three other vehicles so the truck only gets used for hauling/towing- either the trailer or hay/lumber. The ride was a bit stiffer with 80 PSI than with the 60 it left the dealership with, but it is a truck, I really don't mind if it rides like a truck. They new 2010 SRW 3500 Ram rides smoother with 80 PSI than either of our Jeeps do (even the 2009 Jeep).
aegnc
Reg. Sep 2007
Posted 2010-05-04 9:06 PM (#119727 - in reply to #119634)
You might want to check the placard on the driver's door.   It'll tell you the manufacture recommended pressure at the GAWR's for each axle.  With 3000 lb in the bed you should be under these for a '99 dually.  My guess it'll say ~80 psi for front and ~ 65 psi for rear.  On a dually, the front tires are more heavily loaded than the rear tires.
