Window Replacement
Last activity 2010-05-24 3:54 PM
8 replies, 5669 views
RWR
Reg. Nov 2009
Posted 2010-05-01 10:09 AM (#119581)
Subject: Window Replacement
I am looking at a 4h Platinum that I found a smoking deal on. Only problem is it has bus windows on the butt. Anyone ever had Bus windows removed and drops installed?
Posted 2010-05-01 11:46 AM (#119585 - in reply to #119581)
Subject: RE: Window Replacement
If you could find a drop window that is the same size, It's probably a doable project.  But most drops are bigger than the bus windows and that probably would require a LOT of structural change to the framing. Which would make the project too expensive to be practical.
RWR
Reg. Nov 2009
Posted 2010-05-01 12:38 PM (#119587 - in reply to #119581)
No such thing,,,,,,,,,,,,what I am thinking of doing is buying the drops from Platinum and having them installed. Just curious if anyone had ever done it.
Posted 2010-05-01 2:19 PM (#119593 - in reply to #119581)
Contact Platnum and see what they say. As PH said, the window sizes are not usually interchangeable and could require structural changes for an installation
randemtam
Reg. Jun 2007
Posted 2010-05-01 3:41 PM (#119594 - in reply to #119593)
10010010010025
I am by no means an expert but, I do remember being told that the regular windows on an Exiss I was looking at could be replaced with a drop down window. At the time I wasn't quite sure the salesman knew what he was talking about but saw them later. They are not the big drops like they are on the front but look like sliding windows that actually fold down. Shadow uses these on many of their trailers and they allow a lot more air flow than the sliders. Good luck!
Edited by randemtam 2010-05-01 3:42 PM
RWR
Reg. Nov 2009
Posted 2010-05-01 5:23 PM (#119595 - in reply to #119581)
Ok, I guess I didn't make myself very clear. I know that the windows are not the same size and that there will be some major work needed to do make the replacements. I also have spoken to platinum dealer and the factory that said yes it can be done. I guess what I was asking is if anyone had done it and what sort of luck they had with it.
y_do_i_do_this
Reg. Jun 2009
Posted 2010-05-24 9:56 AM (#120487 - in reply to #119595)
did you ever find the answer to your question?  I am in the same situation.  Found a Platinum but has the sliders on the rear.  way too hot here for sliders, have to have the drops.
Posted 2010-05-24 2:29 PM (#120503 - in reply to #119581)
How about these drop down windows that Shadow and Sundowner are using..... Would they work??
<script> window.setTimeout("watermark()",50);
Tresvolte
Reg. Feb 2008
Posted 2010-05-24 3:54 PM (#120505 - in reply to #119581)
There are also some smaller ones out there.
