generators & AC
Last activity 2010-04-15 6:29 PM
3 replies, 3957 views
bovinedoc
Reg. Apr 2010
Posted 2010-04-13 6:51 PM (#118769)
Subject: generators & AC
Anyone running 13,500 btu AC with a yamaha ef2400is generator. I would like your experiences. THANK-YOU
wyndancer
Reg. Apr 2007
Posted 2010-04-13 9:02 PM (#118771 - in reply to #118769)
Subject: RE: generators & AC
Yes, does just fine. But it is using max output when starting.
I believe if you are running the AC, that's all you're gonna run. Well the converter will run as well, but not the microwave, nor a coffee maker.
Posted 2010-04-14 5:42 AM (#118782 - in reply to #118769)
I used the Yamaha EF2400 on my trailer.  As long as I didn't try to run another other major appliance at the same time. It ran the A/C just fine.  When ever I needed the Microwave, I'd turn off the A/C
BlazingCreekBar
Reg. Nov 2008
Posted 2010-04-15 6:29 PM (#118903 - in reply to #118769)
We have one too.  I find it works just fine.  I like its light weight mobility design.
 I take precautions prior to starting the AC.  I set the fridge to gas only.  I wait a few minutes after starting the Gen letting the electrical system settle.  Remeber if your batteries are low the converter will go into high charge mode.
I only had issues when I rushed to turn on the AC.
I always start the AC in the warmest setting and once the power is applied I slowly turn the thermostat until the compressor kicks in.   I shut off any power vents that take electricity also.
We have no Microwave.  But have showered and enjoyed Hot dogs and cold beer after a hot ride many times in the AC.
When we ordered shipping was free.
http://www.wisesales.com/YamahaEF2400iS.html
